The HP loss is the same at 10 mph as it is at 120 mph.
Stopped racing and became a drummer |
There are AL threaded valve stems available. I think I saw them at Jeg's or Summit. By reducing the weight of the stem itself (I mean how much do those steelies weigh anyway?), one could assume that one could add back a little weight. Certainly something perched on the top of a stem at any appreciable angle, and given the forces you guys have come up with, the bending over of the valve stem has to be considered. The rigid AL stem would do that job.
The balancing guru that I listen to, Nate Jones of Nate Jones Tires, and balancer extraordinaire for Bonneville cars and bikes, explained this to me some time ago. He didn't run the calcs for me, just told me that a quarter once at speed weighs POUNDS. His thesis has always been on truing tires before any balancing. As he explained, the weight of the encentric portion of the tire tends to exacerbate the problem as the tire grows even more out of round at spped. Of course, he started doing this 40 years ago when tires were not as round as they are today. Nevertheless, at 300 MPH, it has to be a very critical item on the car (or even bike nowadays). These little tire pressure monitors need to be some how tapped into the side of a special valve stem enabling better placement, IMHO. They would be hidden, to some extent, as well. |
I'd just get the strap on things that mount to the whel circumerence inside the tires. They have radio transmitters that a receiver in the car picks up.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I have to tell you that there's no way I'd put something that big and heavy on my valvestem.
If I want a monitor I'm getting one of the in tire models.
Interesting calculations, you guys are scaring me about my big lathe though. The 4-jaw check is 18" diameter and each jaw weighs about 10lbs. It spins as fast as 1800rpm. I don't even want to think what the dynamic weight of those jaws is.
Anyway, I'd recommend against the all threaded valve stems. Those threads create a stress point that would eventually snap under repeated loads listed above. In fact I'd recommend against steel stems period as they all have some threads exposed I believe. I ran them on a 4x4 until I snapped one out in the woods in a deep mud pit. Now if you ran those little stem supports with rubber stems and rebalanced the wheel I think it would be fine. Oh an the calculations missed one thing, the stems aren't at the radius of the wheel, they can be as much as 3/4" closer to the center depending on the wheel.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Super Moderator
bringing the stems in 1" only reduces the force by 100 G's or so...
I think we used the same formula since w*r = velocity, w = v/r What units did you use for the mass? |
Kantry Member
There is another factor involved.
All calculations so far apply to a spinning wheel which is not travelling along a surface. In effect, a point on the circumference of a wheel has no forward velocity while it is in the plane between the axle centre and the surface upon which the wheel is travelling. It is then accelerated to twice vehicle speed as it passes through the plane above the axle then decelerates to a "stop" again. The effect is reduced as you return to the centerline of the wheel. I suppose this effect is an order of magnitude less than the rotational forces, but they could certainly add up at 150 mph, as the valve stem would accelerate to 300 mph and back to 0 several times/sec. (Kind of makes you glad you weren't born a valve stem, doesn't it.) Les
Best Les My train of thought has been replaced by a bumper car. |
valve cap is 9" from the axis orf rotation
Super Moderator
Just realized that I screwed up and used the diameter rather than the radius!!! (My math teachers would be aghast.)
LETS TRY again using 9" radius : ((176 * 176) / 32.2) / 0.75 = 1282 G's... er.... Well anyone figure that out? Now I've confused myself. It's really the old F=ma calculation... Perhaps it's ((176^2) / 32.2) * 0.75 = 721 ?!?! Ahh,.. Now that I've sufficiently confused the issue, Chris OUT!
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 10-05-2006 at 07:23 AM.. |
), but somehow I don't think the valve stem knows about the road and therefore, the acceleration and deceleration you allude to. Now, there may be some of that effect when the vehicle is braking or accelaerating (such as wheel spin or the awesome acceleration of a drragster), but I question this at a constant speed. I'm not picking nits here, I'm learning by questioning. Comments?
The load of an object on the valve stem attached to the valve stem is cyclic. Remember that the tire rotates about the ground not the axle.
E.g. the top of the tire is moving at 240mph... so there may be some "radius" adjustment needed in the calculations. |
Your equation is normalized to 1 pound weight. If it weighed .35 oz or had a mass of .00068 slugs it would have 28 pounds of force on it. |
I think BK911 has the correct answer. You have to get the angular velocity from the total diameter of the wheel and tire (DOH) and from that find the centripetal acceleration at the radius of the rim. The tangent of the rim is not going 120 mph, the tangent of the tire is. Oops
>> 26"od = 6.8' circumference >> 9"r = .75' >> 120mph = 162.4 rad/sec >> .35ozs = .022 lbs >> >> F = m w^2 r / g >> >> = .022 0.75 162.4^2 / 32.2 >> >> = 13.4 lbs |
Super Moderator
So I was close originally then...?
angular velocity of 235/35x19 Michelin PS2 26" OD 799rev/mi @120mph is
revs/sec radians/sec
And I thought this would be easy.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Where F is lbs
F=M(V*V)/R*32.2 M lbs V ft/sec. R radius in ft. Problem: What is the G force or Weight of a 0.35 oz. Object on a 18" wheel on a car going 120 mph. Object is 9" from the center of the wheel Tire:Michelin Pilot Sport 275/35 ZR18 Tire dia. 25.7" Revs per mile 807 Revs @ 120 mph 1614 revs/min V @ 120 mph 9" radius on a 25.7" tire Radius x 2 x PI x 1614 .75 ft x 2 x PI x 1614= 7605.7596 ft/min. 7605.7696/60= 126.7632 ft/sec V= 126.7632 M= .35 oz. M= 0.021875 R= .75 ft. F= .021875 x (126.7632 x 126.7632)/.75 x 32.2 F= 351.5077/24.16= 14.55 lbs @ 120 mph G= 14.55/.021875= 665.38 G's @ 120 mph
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red Last edited by 2.7RACER; 10-06-2006 at 10:52 AM.. |
Driving member
You guys are too funny. If anyone needs any problem analyzed to the point of distraction just post it here. All these engineers and there is really no one that can drive the train.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
