I need heat in 911 with headers
I have a 1980 911 with headers and i'm moving north. Any ideas on a heater for this situation?
Old 10-04-2006, 08:23 PM
Alii&Maui
Jesset100's Avatar
not mine but good idea
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 10-04-2006, 08:28 PM
911Velocity's Avatar
Re: I need heat in 911 with headers
Buy a set of SSIs and switch for winter. That's what I do. Sorry no other help that I've found.
Gerry
Gerry
84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette
06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd
65 Chev Nova 385 Race, 85 Chevy Rollback
97 Ford Exp. EB, 90, 91 Toy PU
Old 10-04-2006, 08:32 PM
WydRyd's Avatar
I have the above oil cooler heat exchanger (bought from Protomotive). Works well with the kick panel blowers drawing in a steady stream of warm air (once the motor settles at normal/steady operating temps). Better than nothing!
Not too sure how well it would work in sub-zero climates though
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-04-2006, 08:51 PM
A Quiet Boom's Avatar
Would the oil cooler setup work well enough for keeping fog off the windows on cool autumn and spring nights? I'm putting Bursch headers on the track car and was thinking of using an RV heater in the front truck, this looks alot lighter.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 10-04-2006, 09:28 PM
WydRyd's Avatar
Not really effective at doing this, because it takes time to draw warm air into the cabin (I'd say 15 min). The engine oil has to be at "normal" operating temps before it'll really start working well enough and the car has to be moving for the air to circulate sufficiently.
I was thinking of perhaps fitting an extra pair of auxiliary blowers earlier in the duct path, to get the air moving faster.
Merv
'89 911 Turbo Cab
Old 10-04-2006, 09:39 PM
Sleep Deprived and Grumpy
jwernquist's Avatar
There where a few people talking about this. Might want to search the forums as I dont remember the actual thread however. You can have small boxes welded to the Headers. Talk to Ben at MK Exhaust he and I were talking about doing this with my headers. It would be pretty easy . However it would not be super heat it would probably just help with the cold!
jwernquist@wi.rr.com
262.215.6547
Old 10-04-2006, 09:45 PM
randywebb's Avatar
Webasto heater in front?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-04-2006, 10:21 PM
jwernquist's Avatar
Heheh I actually have a couple of those from some VW Things. They kind of scare me.
262.215.6547
Old 10-04-2006, 10:23 PM
I'm talking about driving on cool damp days after the car has warmed up, I get fog on the inside of the windows. I figure a gentle stream of moderately warm air might fix it. I don't drive the 911 in the winter so no need for real heat.
There was a thread a while back on this wherein I suggested the RV heater.
jluetjen's Avatar
Guys, just get a set of SSI's or factory early style heat exchangers. How many HP do you really think that you're getting using the headers over the stock early style system? Especially for street use. This poses an interesting set of questions, many of which can be answered by people on this BBS since most of us have parts laying around.
1) Weight of the factory (early style) exchangers?
2) Weight of SSI's?
3) Weight of headers + welded on heater boxes
4) Weight of headers + auxilary heater such as a Webasto.
I'm not sold on the oil-heater thing given how long it takes to become really effective. Also keep in mind that on cold day, the engine doesn't get as warm, so it will take longer and longer to get any sort of heat out of the system. This isn't particularly helpful if you're trying to de-mist the windshield with the sun in your eyes during a morning commute.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-05-2006, 05:09 AM
SSIs are the only way to go. what displacement are you deeling with??
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-05-2006, 05:17 AM
I'm not understanding what SSIs have to do with it. I have SSIs, and they're "headers." They have no heat muff.
I blocked off the left side of the air shroud and installed a stock outlet on the right side. Hot air flows from there to a tee about 10 inches away, and from the tee to the right and left heater valves. I also installed kick-panel blowers, which I rarely use.
Works fine for the situation you're talking about--moderate winter temps. (I live inthe Hudson River Valley but stop driving the car when it starts to snow.)
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-05-2006, 05:47 AM
Steve,
So your heated air does not go through any heat exchanger, just warmed from being over the engine?
I have the same need as you, just a bit of warmth for cooler days. Last winter (my first) I drove on a few dry but cold days and the toes got numb! This winter I'm doing head studs and planned to add SSIs, but if this works it will save some $$.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 10-05-2006, 05:55 AM
steve no offense but not sure if you are understanding that there are stainless steel headers(which get confused with ssis brand) or ssi which is an early pre 74 style heat echanger made by john daniels of stainless systems inc which has a heat muff around it just like the factory did but better with an optimized equal length header inside. visually they look just like the early exchanger but look much higher quality.
I could be wrong but thats what your explaination says to me.
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-05-2006, 06:01 AM
No offense taken! I didn't know that's what SSIs were. I thought I had SSIs, which in my case are simply stainless-steel headers...
Stephan Wilkinson
Old 10-05-2006, 06:11 AM
gestalt1's Avatar
how about having an upholstery shop add electric seat heaters? also, windows fogging up is caused from warm humid air from the passengers condensing on the inside of the windows. if outside air is ducted directly to the defroster vents i would think this wound reduce the fog. this would be cold air but it would work and the seat heaters might be enough buy themselves. there is also that rain-x anti fog stuff that might help.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 10-05-2006, 06:25 AM
I use simply cold air for windshield defrosting. Works fine.
Stephan Wilkinson
Old 10-05-2006, 06:31 AM
MBruns for President
JeremyD's Avatar
SSI or B & B Headers - the make B & B with heat exhangers or without.
Old 10-05-2006, 07:21 AM
Where are you moving? I have a B&B setup lying around that I'd sell you. heat worked great when I had it on the car.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 10-05-2006, 07:26 AM
