jorisg
Guest
Posts: n/a
Fuel
I hope that some one can give me some advise on what fuel to use on a '75 European 911S with a 76 2.7 engine.
I have asked around at the several "Experts" but I do not get a conclusive answer. while one mechanic is saying that therer is absolutely no problem to use regular un-leaded 92ron, another mechanic is saying, oh no you have to use the good old leaded higher octane fuel.
Can any of you help me out??
Joris
911S 75
Old 06-30-2000, 12:36 AM
Superman
Guest
Posts: n/a
You will never hear the end of that debate. I believe the 'specifications' for most all our cars allow regular gas. I believe it is 'supposed' to be oday for my car which has a 9.3:1 compression ratio. I use mostly Chevron Super.
Again, presumably regular is fine. But the penalty for using gas wiht insufficient octane, is detonation. A severe penalty.
I use a strategy of slightly rich mixture, ignition not too advanced and high octane gas. From there I could cheat a little on any one of the three and probably be safe.
If you want to use regular gas, it would be a good idea to make sure your car is tuned properly, and I suspect everything would be fine.
Higher octane gas does not have more power. It simply resists detonation better. Bruce Anderson wrote the best description of detonation I 've seen, by the way.
'83 SC
Old 06-30-2000, 07:00 AM
jryerson
Guest
Posts: n/a
Most 911s from about 74-80 had a compression ratio of 8:1 which is fine for regular gas and should experience no detonation, after 80 they raised the comp to 9:1 which would require Premium Fuel
Old 06-30-2000, 07:54 AM
jorisg
Guest
Posts: n/a
Thanks guys, for the advise. I guess smartest thing to do is just use leaded premium fuel.
Joris
911S
Old 07-01-2000, 01:30 AM
