JV44HeinzBar's Avatar
valve adjustment
Hi all,
I've been hesitant about doing a valve adjustment myself without having actually seen one done before. However, after getting some quotes from the local mechanics, I'm more inclined to do it myself. But, if I can get a confident mechcanic to do it for me, I would be willing to pay for the extra satisfaction that the job was done right without having to worry that I screwed something up.
So, would any hazard to guess what a standard valve adjustment would cost in your region? I currently live in Maryland, so I would like to get a fair price estimate for doing a valve adjustment here. I would kinda like to know if I'm being conned or are these quotes legitimate? Can anyone help me out?
TIA,
Brent
Current:
1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun!
1971 911 T Targa Signal Yellow (summer joy)
Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green
Old 10-04-2006, 06:17 PM
jimi_c's Avatar
$400 - $500 is what you'll pay up in the Philly area, I'm guessing you'd see the same down there. Don't think you can't do it though - search the forums, have the right tools handy - you can do it and do it well.
The first time I did them, it took about 4 hours - 1 hour to do the work, and 3 hours to second guess myself.
Cory H
85 Carrera
Old 10-04-2006, 06:22 PM
<insert witty title here>
Christien's Avatar
Yep, I'll second what Cory said. Do it yourself. I did - first time took me most of the afternoon, then did it again the next day because they were ticking. I still wasn't satisfied so did it again a few weeks later, and the car ran better than it ever had. And this is from someone who, when I bought my car in Nov/04, couldn't even identify which part was the carburetor
The trick is knowing what "just tight enough" feels like on the feeler guage. Search here for a good description of what the right resistance feels like, or even better yet, have someone show you. Once you've got that down, it's a walk in the park. (with a bit more backache!)
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 10-04-2006, 06:33 PM
76carrera3.0's Avatar
Do a search and look in to using the .002 /.003 feelers on the rocker to cam lobe technique can't go wrong doing it that way. Maybe someone can post a link to that thread for ya.
Old 10-04-2006, 06:58 PM
bcr4d's Avatar
reply
I also was a little hesitant about adjusting my valves. I asked many questions on this forum and finally built up enough nerve to do it myself. Wasn't bad as I thought it would be. The first time I did it they ticked, so I did it again about a week later. Now the valves are quiet and it runs like a scared puppy. Believe me, you can do it.
Billy Crawford
Old 10-04-2006, 07:20 PM
Zeke's Avatar
The top (intake) valves are pretty easy to do. I'd say, get Wayne's book (if you haven't already) and a valve cover gasket kit and do the top, at least one side. Shoot, at least just one. If you don't like how it's going, take the rest of the kit to your mechanic and let him finish it.
BTW, valve adjustments commonly coincide with an oil change because the oil will run out of the bottom covers if it's not drained beforehand. Some raise the car from one side to keep the oil in while they tackle the high side exhaust valves. This is especially handy if you feel that one is not quite right. You don't have to drain the oil to go back and redo. The top valves can be worked on with the car on the ground. It's a good place to start and relatively safe. If you're comfortable, keep going. BTW#2, you can button things up and take a drive after doing just the top to see how you did. You will ahve to let the car cool for literally hours before you can get to the bottom, if you decide to test your beginning work. Do the tops all you like until you get it right. Don't make them too tight. Especailly the exhaust valves, but they all need to be pretty exact for the best performance and the nice quiet sound.
Old 10-04-2006, 07:23 PM
Super Moderator
cstreit's Avatar
Typical valve adjust is around 3-5 hours depending on the car. Multiply times the labor rate...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-04-2006, 07:24 PM
Christien's Avatar
Oh yeah, spend extra for the silicone gasket kit!! I didn't, and now enjoy the lovely smell of oil dripping onto my heat exchangers and burning.
Old 10-04-2006, 07:44 PM
khamul02's Avatar
silicone gasket kit!! Best money I ever spent
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 10-04-2006, 07:51 PM
jimi_c's Avatar
Here's the link to the post that 76carrera3.0 referred to:
valve adjustment
Cory H
85 Carrera
Old 10-05-2006, 07:29 AM
Wash. State
nesslar's Avatar
Talking
See Doug's (2.7racer) Tech Info Forum article "911 Valve Adjustment-The Backside Method". You'll find that on the Pelican home page, then click "Tech Info Center", then click on "911 Series", then click on "911 Technical Articles", and finally Doug's masterpiece. I think it's the sixth article from the top of the list.
Always liked a nice "backside"......
Old 10-05-2006, 07:45 AM
Somatic Negative Optimist
Gunter's Avatar
Leaks can happen when:
Both sides (Case and cover) have not been cleaned enough,
The cover is warped.
Put a large sheet of fine sand paper on a sheet of glass and gently pull the cover over it. Check the surface and keep sanding until all is even.
No silicone gasket needed as long as surfaces are cleen and not warped!
An old trick we used in industry is to put antiseize lube on both sides of an ordinary gasket. That way, it'll never stick.
I have been reusing the same old gakets (With antiseize on both sides) for the last 5 oil changes without leaks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-05-2006, 08:35 AM
Christien's Avatar
That's amazing! I think it's fair to say you've got more patience than I! I did put the valve covers on a flat surface and check for warps and bends, couldn't find any, and even then sanded them a bit to clean them up. And I added gasket maker to both sides of the non-silicone gasket. Still leaks... Next time I pull them off, I'll try the glass/sandpaper method.
Old 10-05-2006, 08:41 AM
Hi,
Thanks for the great replies. I'm fortunate enough that my Pcar has the turbo cover upgrade, so I hope that minimizes the possibility of warping.
I understand the idea of time x $$ equals the valve adjustment price, but I guess I'm curious if this type of job various greatly depending on location. I'm also still hesitant about doing the job myself without having actually seen it performed in person. I guess I need to get intouch w/ PCA to see if any locals (MD) are doing a valve job soon. Maybe I can get invited to see how it's done in person..hint, hint
Sincerely,
Brent
Current:
Old 10-05-2006, 11:17 AM
Just finished this today!
Used the "Backside"/"Go No-Go" method and only needed to adjust Cylinders 1 and 6!
Had a friend help from under the car while I was checking from the engine bay.
With the money I saved I'll be getting an SW chip...
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 10-05-2006, 10:56 PM
durn for'ner
livi's Avatar
I second the DIY advice.
And believe me, if I could pull it of - anyone can ! I have five thumbs on each hand and no tech education or inclination what so ever. Just a burning desire to learn.
Markus
Resident Fluffer
Carrera '85
Old 10-06-2006, 05:12 AM
Christien's Avatar
I guess it would depend on how good the mechanic is. Say they each charge $60/hr for labour, someone who's done lots of adjustments on 911s could do it in say 2 hours, plus parts, total bill under $150. Someone who's equally as competent but less familiar with the procedure might take 3 or 4 hours, plus parts, total bill closer to $300.
Old 10-06-2006, 05:36 AM
S2GART's Avatar
Just a quick valve adjustment related question, how often are you guys doing them?
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 10-06-2006, 06:49 PM
I would just pay someone to do it, honestly it so much easier .
Old 10-06-2006, 06:55 PM
p911sc's Avatar
I was just reading this earlier tonight. Wayne's book recommends every 10,000 miles on later model 911s (1978 and later) and every 6,000 miles on older models.
Anyone know why the difference?
Rick
Old 10-06-2006, 07:09 PM
