-   -   Why does car run hotter with A/C on? (http://forums.pelicanparts.com/porsche-911-technical-forum/30831-why-does-car-run-hotter-c.html)
ewr1 06-27-2000 07:06 AM
I am embarrased to ask but I have to know. Load on engine from the compressor? Heat from condensor in engine compartment? Thanks!
roGERK 06-27-2000 08:47 AM
You're absolutely right - both! Although the increased load on the engine is probably the major cause.
BUT! The AC should make more than a few degrees of difference, if you are seeing a big increase in the temp, something is wrong.
- roGER
adamnitti 06-27-2000 09:53 AM
just how high can the temp get before it's considered unsafe? i was in traffic yesterday in atlanta heat with a/c on, and the needle crept up to just below the last white line before the red. does this sound pretty typical for a 911?
Adam Nitti www.adamnitti.com
'85 Carrera
'74 3.0 CS
[This message has been edited by adamnitti (edited 06-27-2000).]
ewr1 06-27-2000 11:00 AM
My oil temp gets to just above the last white mark...it makes me nervous! I can't decide if the ambient temp is just so high (95+ here in South Carolina) that the car can't cool down of if it is the A/C...
Leland Pate 06-27-2000 11:48 AM
Adm, I was checking out your website and....you "know" Victor Wooten???!!!
Are you kidding me? Thats bizzar.
I've played percussion since I was 12. My little brother is a bassist.
Neat
Leland Pate
___79 SC Targa
chuckr 06-27-2000 12:41 PM
I was just logging in to ask about engine
temps...my 83SC has just had a new A/C,
Sanden Rotary, new everything!! My temp
needle,in traffic, stays around the top white
mark before the red. It's been real hot here
in Austin,Tx lately so I guess that has something to do with it BUT, I have been
considering putting a auxilary oil cooler
to replace the trombone cooler,anybody done
this ? how much does it help.
jryerson 06-27-2000 12:48 PM
Here in Vegas we get temps to 122' and the only way I can run my A/C and keep my SC cool was add a Carrera oil cooler to the fender and a Spal fan to cool it otherwise my temps would get to 250'+ real quick
Sputterbug 06-27-2000 12:55 PM
Hey Leland/Adam,
We have the makings of a 911 band here. Mark Szabo and I are both guitar nuts. I also play bass and drums. Name suggestions?
The Swepco Swingers
The Notchy Shifters
Exploding Rubber Clutch
Chain Link & the Tensioners
[ouch - I'll stop now]
Roger
'85 Carrera 3.2 Coupe aka "Sputterbug"
http://www.rogerplacer.net/911/
ewr1 06-27-2000 01:00 PM
I have an '88 Targa so I have the 'good' cooler. The fan cut on for the first time the other day...
chuckr 06-27-2000 02:24 PM
OK, after my last post I ordered
a cooler, it is not going to have a fan.
Where can I get THE fan ?? has anybody
installed the auxiliary cooler themselves?
It was also recommended for me to install
a screen. what kind of screen and where do
you get a screen?... I just spent $2,000.00
on a new A/C. I', trying to save some money!
T.I.A.
ewr1 06-27-2000 03:42 PM
For sale - 1989 '52 reissue Fender Telecaster with Joe Barden pickups. $1200. Email William.Reinecke@Mindspring.com
For the new band...
nhromyak@yahoo.com 06-27-2000 04:20 PM
I would like to get the fan too.
I have an '85 with the radiator type cooler...
Nick
team5150 06-27-2000 04:23 PM
Chuckr -
I installed a Mocal Cooler and thermostat that I got from Pelican a few weeks ago and the difference is dramatic !
I used to run at or over 250 all of the time and now the temps are down to under 210 and never exceed - it even on the 100 degree days we've had here lately.
I put the installation on my web site with pictures so that you can see what your in for. Go to
http://members.rennlist.com/5150targa
You can also see it on the Pelican Tech Articles section at
http://www.pelicanparts.com/techarticles/tom_sharpes/oil_cooler1.htm
By the way the Mocal cooler and t'stat with hardware and everything is about $700 from Pelican !
Good luck and if you have any questions just email me.
Tom Sharpes
74 911 targa
valerie 06-27-2000 05:41 PM
I have the factory oil cooler fan in the front wheel well in my 87 Carrera. Rigged a switch and a wire to start the fan when I want to. Here in the wilds of Conn, the fan never came on automatically. On this list last year,someone found a Mercedes thermoswitch that fires it up at a lower temp, but thats another project.
Ned Monaghan
jryerson 06-27-2000 07:09 PM
THe Cooler will not do you much good in traffic unless you get the fan,
You can order thru BAT in Fla for a Spal fan about $80.00 I dont know their ph # but you can do a search under "fan" and find it on some old posts.
campbellcj 06-27-2000 07:48 PM
Um, what's AC? http://www.pelicanparts.com/ultimate/wink.gif
Two targas..."100% natural AC" only...
Chris C.
[This message has been edited by campbellcj (edited 06-27-2000).]
patalive 06-28-2000 03:52 AM
I agree with Jeff (jryerson) - adding the Carerra cooler without the fan will yield only a small benefit in heavy traffic. However, on the highway, I do notice a significant improvement in temps. With AC, on a hot, sticky day in the DC area, temps now around 210 - previously about 230/240 with the trombone. When I come to traffic - lights, stop and go, I flip on the fan to hold the temp to a max of about 220.
The SPAL fan is available from BAT Industries (dealers for MOCAL) phone 941-355-0005 - or visit web at http://www.batinc.net They have a very good catalog pdf file with oil cooling equipment, mostly for Porsches.
To the poster asking about the screen - the stone guard fitting over the cooler is a stock Porsche item - about $65 - you should also get the foam gasket that goes around the cooler to prevent cooling air from going around the cooler rather than through it. The foam item is $70 (ouch!!).
chuck
old_skul 06-28-2000 05:23 AM
$1200 for an '89 Tele '52 reissue? Gads, is there a Porsche Tax added to that? Shew...
I just bought two more gitters so I can't really splurge again.
Heh..."Exploding Rubber Clutch"....we'd have to be a techno band.
Mark Szabo
1986 911 Targa 3.2
adamnitti 06-28-2000 07:41 AM
sorry for the waste of "band"-width, everyone...
(i couldn't help it)
the exploding clutches is a great name. on a serious note, i just finished recording a tune called "911" on my new record. we'll have to add it to the set.
thanks to everyone up here helping out car idiots like me. i REALLY appreciate the great advice and suggestions!!!!
Adam Nitti
www.adamnitti.com
'85 Carrera
'74 3.0 CS
Andras Nagy 06-28-2000 07:50 AM
Tom:
I really don't want to rain on your parade, but when you modified the stone shield behind your cooler, you also inadvertently made the cooler less efficient. I looked at your pictures, and saw that you had cut off the round top.
The reason the stone shield was shaped like it was, is that with the round top and the rubber gasket, it meant to seal the cooler into a force-feed situation, in which all the air around the wheel well was forced through the cooler, not allowing any air to spill around the cooler, and this not through, the cooler. This is harder to describe than to understand, but Porsche, in their infinite wisdom, realized that with all the air turbulence around the cooler, they had better FORCE the air the go through it. Hence the shape of the stone shield, and the purpose of the rubber gasket.
The fact that you are still getting good cooling is a tribute to the more efficient radiator cooler. Think how much more efficient it could be if you had air being forced through it, too......Andras
chuckr 06-30-2000 04:45 PM
Does anybody know where I can get a 61/2"
pusher fan for my Mocal Loop Replacement
Kit ?? BAT in Florida has them on back-
order,I've read in pervious posts about a
Spal (?) The post I read gave a web address
but when I tried to link to it I got server
not found,My Kit is due on Wednesday,need
fan bad !... oh yea... I also need screen/
rock guard, what year car did Porsche start
using fender mounted coolers and how big
were they, I've got a 19 row, will a Porsche
guard fit ? I also found Warren's post on how
to wire up the fan ! If I just had a fan.
scott matre 07-03-2000 07:19 AM
You can get the parts from WWW.Racerpartswholesale.com
scott matre 07-03-2000 07:29 AM
Just as a thought.. YOu might check out my earlier posts on cooling fans.
Cooler Carrera dated 4/11/00 and Fan Update dated 6/12/00.
I have had these fans installed for about 3 months now and can sit in 95deg traffic all day with the AC on and never heat up.
chuckr 07-03-2000 10:32 AM
Thanks, Scott !!
The Spal is a couple of bucks cheaper and I
can get one NOW, I've read your posts and
am using all the info I've obtained to do
this myself! Thanks again.
oh, yea.... I did read a post that the spal
was noiser than the Mocal,any thoughts on
that?
[This message has been edited by chuckr (edited 07-03-2000).]
