-   -   Lsi? (http://forums.pelicanparts.com/porsche-911-technical-forum/308333-lsi.html)
por73911 10-07-2006 07:36 AM
Lsi?
How can you visually tell that you have Limited Slip?
Steve@Rennsport 10-07-2006 07:50 AM
Paul:
The easiest and best way to tell whether you have an LSD in your car is by lifting the rear wheels clear of the ground and putting the transmission in neutral.
Rotate a rear wheel while observing the opposite side one. If they rotate the same direction, you have an LSD. If they rotate in opposite directions, you have an open differential.
por73911 10-07-2006 07:55 AM
Thanks Steve
