930 trailing arms
What is the easiest way to identify 930 trailing arms?
By their size and hub widths,...:)
Any measurements?
Steve's right. The 930 trailing arms look like they are on steroids. Much beefier and the arm tubing almost has a square look to it.
I guess as far as measurements, you could look at the holes for the rear caliper spacing. Figure 74-89 trailing arms have a 3" spacing while the turbo arms have 3.5". The turbo arms also allow the hub to sit out AFAIK remember 1" more than the standard ones. Of course that might be a bit harder to measure since you would need a right angle. Hope this helps a bit. |
Joe:
They are easy to spot simply by observing the cast lugs for the brake caliper mounts that lies BEHIND the axle centerline, instead of in front, like the 911 ones. |
Ahh, thanks guys. Steve, I had forgotten that!
| All times are GMT -8. The time now is 03:31 AM. |
