Oxford_Hippo
Guest
Posts: n/a
Question Procedure to Bump start a car??
Confessing to never had to bump star a car before.
what is the best way of doing this?? Car in gear etc. etc.,
THanks,
A. beginer
Old 10-07-2006, 05:09 PM
lazylongboarder's Avatar
It really depends on the circumstances and no particular way is safer than others but this is what i do when the unfortunate event arises (drove a 74' beetle through high school with a bad starter)
#1. Park on a hill (if no hills, move to #2 [hills-move to #3])
#2. Have a pusher and a driver with enough dexterity to push with the door open and hop in without loseing your ride to you tripping and having your beautiful (why doesn't it start again?...but its sure beautiful) 911 smash into traffic with no driver.
#3. Hop in, slam the door closed.
#4. Make sure the freaking key is on! Cause if not you sputter to a stop with no ignition and you feel even more like a moron cause your already pushing your beautiful 911 right.
#5. Clutch.
#6. Select 2nd gear if you are going over 10 mph, under 10 mph use first, it's just harder on the drivetrain.
#7. Drop the clutch with the key on with enough speed, if you have to, give the gas pedal some love.
#8. HOUSTON WE HAVE IGNITION!
Old 10-07-2006, 05:34 PM
Just remember, fuel-injected cars must have a battery strong enough to run the fuel pump & ignition system otherwise it won't fire.
This procedure works great for carbureted cars with mechanical fuel pumps and manual transmissions. If an automatic-equipped car happens to have a rear oil pump in the tranny (rare), it works OK on those too.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2006, 08:32 PM
jevvy's Avatar
great tips - also be ready to dip the clutch as it starts or you will set off pretty quickly!
'89 3.2/3.6 coupe
Old 10-08-2006, 02:33 AM
Driver Ed's Avatar
You can also start it in reverse. I've had to do that once in my 911 in a parking garage when the starter motor started going bad. Same procedure; just get it up to speed and pop the clutch.
However, it's less safe because rather than losing the car if it gets away from you, you'd get knocked down by the door and run over. Forward is preferred!
2000 Porsche 911
1982 Porsche 911 SC Targa
Old 10-08-2006, 04:44 AM
Somatic Negative Optimist
Gunter's Avatar
I found that the easiest way is to use 4th gear with ignition on.
The ratio in 2nd, or reverse, is just too rough on the power-train.
If your battery is good, turn ignition on, roll down the hill, put it in 4th and release the clutch.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-08-2006, 08:16 AM
Sounds like Grunter...ahem...i mean Gunter has pushed his car a few to many times . Thats not to bad comparing that i had 9 flat tires in one month...but that should be under "how many spares can fit in YOUR car?"
Old 10-08-2006, 01:08 PM
