-   -   I've asked this question on numerous sites (http://forums.pelicanparts.com/porsche-911-technical-forum/308348-ive-asked-question-numerous-sites.html)
Stuart993 10-07-2006 10:43 AM
But unfortunately with no real answer:-
Has anyone else had this happen?
On starting the car, in the morning, the fan switches on and operates in fits and starts. All heater switches are off. This doesn't happen after the car has been stood all day, just in the mornings.
The fan stops after about 20-30 seconds.
Any ideas?
Thanks in advance.
spikej40m 10-07-2006 03:07 PM
WHAT YEAR CAR ARE WE TALKING ABOUT?
Stuart993 10-07-2006 03:36 PM
1995 993 Cabriolet.
David E. Clark 10-07-2006 03:46 PM
Have you tried posting this on the 993 Technical Forum?
CharlesJones 10-07-2006 04:21 PM
Is it something to do with the heater blower relay? I know my car is much earlier than yours, but I used to find that my heater blower would work eratically, so I took the relay out, removed its metal cover and cleaned it, popped it back together, and my problem was completely fixed. Dunno if that's any use to you or not.
silverc4s 10-07-2006 05:54 PM
Are you sure it's the fan motor? There is an air pump that runs for 30 sec to 1 min upon cold start only, helps the cats start up nice for min cold start emissions.
Stuart993 10-08-2006 09:20 AM
David E Clark: Yes.
CharlesJones: Thanks, I'll look into this solution.
silverc4s: It's definitely the heater fan, you can feel cold air from the vents and like I said it's sporadic, starts, stops, starts again.
Thanks for the suggestions.
Drago 10-08-2006 11:10 AM
I've been to that forum and left when the third tumbleweed blew by.
450knotOffice 10-08-2006 11:23 AM
True. Not much going on in there. On the other hand, there are a bunch of guys on here with 993's.
Do you have an owner's manual? It could be some "normal" condition that the manual mentions should happen when the car is cold.
Stuart993 10-08-2006 11:48 AM
I have the Adrian Streather 'Essential Guide', but haven't seen any mention of the subject as yet.
I've considered the "normal" condition, but it's the sporadic nature of the fans operation that concerns me, that doesn't feel "normal".
Thanks for the input, I'll keep searching.
