Please help URGENT!! 1989 3.2 Carrera
Hi,
Please can you help a newbie, im trying to service my car (first timer) please can someone let me know the amount of oil i should be putting in in litres? Please help guys! Thanks in advance Terry |
911 carrera 3.2 (1985)
Approx. 10 litres (oil change). Change oil, let it run and check oil level again.
Kees.
one of gods prototypes
i've found this site very helpfull.....
http://www.angelfire.com/az/deaflab/measure.htm it's way to early over here for math.....
Brought to you by Carl's Jr. |
Monkey+Football
Exactly as much as you take out.
Buy enough to cover what the manual says (~10 litres), drain, measure it, replace. EDIT: Bell's right, too damn early. Forgot to add to make sure you check and top off as the manual instructs after you've refilled - on a flat level surface, engine running, at operating temperature.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. Last edited by Icemaster; 10-08-2006 at 05:00 AM.. |
Thank you guys so much, i am pleased to say that the oil has now been changed successfully!
UFLYICU
Put in a conservative amount, then start the motor and WAIT UNTIL IT IS WARM. Then continue to add oil, checking the DIPSTICK. Do not trust the gauge until you have done it a few times and have established the gauge's accuracy.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
a litre is 1.25 quarts, right? 10 qts. with a filter gets the level to half way between the dipstick marks when hot. so 10 litres would be overfilled somewhat.
1 liter= 1.0556 qts
0r 0.947 qts = 1 liter -Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
guess i need a litre of coffee.
