this thread I post here not to open up another can of worms or hijack this thread, rather for the images as they may help with the issue at hand. before: ![]() After: ![]()
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
We built our own adjusters on the factory plate. We made the hole bigger on the clamping bolt and left the bolt in place. I have used them several years and have had no problems. Lots of adjustment and didn't cost anything.
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
UFLYICU
What about a simple block welded to the outside of the block that the adjustment screw goes through, and long enough to provide a slot for the screw stop to ride against?
_______________________ Racer Rix Spec911 #5 prc-racing.com |
I am thinking that with the Metal bushings replacing the Rubber doughnuts that maybe there is more suspension travel because of less "stiction" and maybe the Springplates bottomed out on the Chassis. Which caused the seperation of the outer arm of the springplate? I know when Hayden put his springplates on his 72 911 the car was way to soft at first for that reason.
2006 Cayman S 93 RS America white(now living in Arizona) 1974 911S/CARRERA (now living in Australia) Livermore Ca. |
Would have to be taller though to ensure that things didn't get misaligned when the car was jacked up.
'82 911SC racecar '05 WRX STi |
UFLYICU
The pic shown is with the car off the ground.
"Would have to be taller though to ensure that things didn't get misaligned when the car was jacked up."
The spring plate isn't going anywhere when you jack the car up. Even if you manage to go airborne off a straight jump, I don't think contact with earth will separate the set screw from the stop (other things might happen though). ![]() Although bench-engineering keeps us preoccupied, maybe we should wait for the prognosis before we break out the drill bits and welding rod. Sherwood |
Chuck just to be clear I was talking about the factories compromise, not yours. I think your products are excellent.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Cheers, Jeff
I had the same problem 2yrs ago with a set of Sway-A-Way only on one side. I found it while installation, so it was machined wrong. The retailer called S-A-W they they made it sound like this had never happened before. I had a DE that weekend so I just installed them and hoped for the best. Come to think of it, I never readdressed that issue. I will probably bolt the two plates together:
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
I hope this isn't too common (their QC dept. didn't catch this). The angle between the splined tube and the adjustment lever should be 90º. It looks like they welded it at 87º. If it's off the car, I'd send a consumer unhappy-type letter to WM and see what they say. Don't hold your breath though.
While a nut and bolt would work, rewelding it would be preferable (IMHO). Sherwood |
Any word from Wevo on this issue yet? Having just put these on my car I'm interested in the root cause.
Keith Lally 85 911 Blue Coupe - gone 84 911 Silver Coupe - gone |
My car was picked up at the track and taken to the shop yesterday. Hayden was in contact with the shop and gave them a list of things to check. More next week.
UFLYICU
bump for followup
Spoke with the owner of the shop yesterday. He has been in communication with Hayden. The owner gave my car's rear suspension a clean bill of health. He is going to talk with Hayden again next week. I don't want to get ahead of them...
Anything new on this topic?
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
Yes, thanks for the reminder.
As I mentioned, nothing was wrong with my car, tub or rear suspension pieces. Installation was fine. Hayden, the shop owner and I have all communicated on this. The decision was to replace the current units with new ones and return the damaged pieces to WEVO so they can take a closer look. Hayden thinks that the adjustment screw may have "walked" across the platform over the course of successive loadings, then finally the adjustment plate fell off the platform and was then deformed as seen in the pics. This may have been facilitated by the large amount of adjusment screw that was exposed in the installation on my car - there was enough adjustment to lower the car several INCHES, according to Hayden. The new units will come with shorter adjustment screws, since that much adjustment is not needed for height adjustment and corner balancing. In the meantime, WEVO is going to work on a design modification to the plates that will prevent this from happening in the future. When those are available and they have completed testing them, he'll send me a set for my car. I don't anticipate getting my car out to the track again until next March or April, so perhaps the new ones will be ready by then. The best part about this whole thing was the way that Hayden/WEVO handled things. Not only am I getting replacement parts for free from them, but they are paying for the installation of the new parts and a new corner balance / alignment! Hats off to the best racing parts company that I have ever dealt with! For those of you with either the WEVO or Sway-a-Way plates, I think as long as you keep the adjustment screw low enough you will be fine. Bolting them together is not an acceptable solution in my mind since it precludes the easy adjustment of ride height for corner balancing and/or accomodating different tires in the rear, which in my mind is one of the big benefits of the design over the factory. Perhaps one of the other modifications suggested in this thread would work as an alternative to keep the screw from walking off the platform. Cheers, Jeff
Jeff, I can't say that I'm surprised. Hayden has always been top notch in my book.
This is one of those cases where it could have been easy for a lesser individual to blame the installation, or even the weather, LOL. I have learned that wnen something is needed for my porsche, WEVO, is one of the first companies I look to for a solution. We are lucky here on Pelican that we have quite a few "Haydens" to do business with who also post their expertise. Thanks for the update!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Hi Jeff:
Glad to hear that you will be "whole" again. I'd affirm what you said about Hayden & WEVO. IMHO, these people have set the "Gold Standard" for customer support & standing behind their products. Nobody does it better and I do wish that other manufacturers would follow their example.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Anyone know if WEVO is shipping a newer version now? I was hoping to get a set before next race season.
