Southern Class & Sass
Dixie's Avatar
Question Going from 30mm to 31mm t-bar?
I'm thinking of increasing my rear t-bar size from 30 to 31mm (23mm front) on my '88 Carrera. It sees 90% track usage.
But I'm wondering if it's worth it. Perhaps I can compensate by running a bit stiffer setting on the rear sway bar?
Can anyone calculate what the % change is?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-13-2006, 03:34 PM
Capt:
IMHO, thats a pretty modest change,...
Most people who are doing DE events or racing usually need the most rear stiffness one can get and that means a 23mm/33mm combo. Although those torsion bars sizes sound pretty aggressive to some, these are still rather soft spring rates for cars on DOT tires or slicks.
Without knowing all the details about your car's chassis and wheel/tire specifications, its difficult to say what might work best for your usage. If it were my own car, I'd not change rear T-bars unless you went up 2 or more sizes.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-13-2006, 03:47 PM
Dixie's Avatar
Thanks for the response Steve. I didn't realize there were torsion bars bigger than 31mm.
More importantly, you've confirmed my belief that it's not worth going to 31mm rear bars. I'll just leave the 30mm bars in.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-14-2006, 06:19 AM
PRO Motorsports
Tyson Schmidt's Avatar
What problem are you trying to cure?
It may require something other than a torsion bar change or swaybar adjustment.
If you describe what's happening and when, we can probably guide you to cure it.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-14-2006, 09:04 AM
