pmajka's Avatar
Porsche Crest How many CFM?????
So, How many CFM would a 3.6L push at 6000 rpm ?????
The answer will lead on to a muffler discussion.
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 10-09-2006, 09:49 AM
drl911's Avatar
Re: How many CFM?????
3.6L = 762.8 CFM @ 6000 rpm in total.....
BUT, each piston is only pushing exhaust every forth storke.
So 762.8 / 4 = 190.7 CFM
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 10-09-2006, 10:24 AM
David's Avatar
CFM = [CID x RPM x VE] / [2 x 1728]
Old 10-09-2006, 11:06 AM
pmajka's Avatar
Re: Re: How many CFM?????
Dan
every 4 strokes is 2 rpm, so it takes 2 full revolutions to expel the gas..so, wouldn't it be 762.8 / 2 = 381.4 ?????
88 Carrera
Old 10-09-2006, 12:41 PM
drl911's Avatar
Re: Re: Re: How many CFM?????
You're right. I hastily confused 4 strokes with 4 revs, but obviously 4 strokes means 2 revs.
Dan
Old 10-09-2006, 01:50 PM
jluetjen's Avatar
It's not clear to me that the flow numbers for a muffler in CFM is really going to tell you anything meaningful about the muffler since it ignore the following critical aspects:
Accoustics
Primary lengths (prior to muffler)
Secondary lengths (prior to muffler)
Collector design
I suspect that as long as the muffler outlet(s) have about the same cross sectional area (or slightly larger) then the secondaries going in to the muffler you'll be fine. As example, you see all of these kids with coffee cans on their mufflers which have more then ample flow, but often still hurt the HP.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-09-2006, 04:45 PM
randywebb's Avatar
I agree - it would be useful for a 1st approximation -- like a flowbench for heads. After that, you have more complex issues to deal with.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-09-2006, 05:30 PM
Mad scientist
Peter Bull's Avatar
Another important point is that the combustion will heat up the air / fuel mixture, and thus increase its volume. Therefore the volume of air drawn into the engine is not the same as the volume expelled through the exhaust. The mass will be more or less the same, but because the volume depends on the temperature, which varies throught the entire length of the exhaust system, it requires a lot of math to calculate the volume of exhaust passing through a muffler over a certain period of time.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 10-10-2006, 12:38 AM
1972_911T's Avatar
The other major factor your overlooking is the chemistry of burning fuel and the way intenal combustion engines and all other fuel burning propulsion systems work in the first place, that been that the products of the combustion have a larger volume than the fuel and air burnt in the first place hence what drives the piston back down the cylinder. So to work this out you would have to start looking at molar values of whats put in to what comes out. Anyone got a periodic table and a few hours?
I mole of any gas = 23 liters at room temperature IIRC
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 10-10-2006, 03:26 AM
David's Avatar
I guess I was just looking at the CFM question and didn't notice it was related to a muffler. I agree with what the others noted here. This calc is for intake sizing, not exhaust.
Old 10-10-2006, 04:55 AM
pmajka's Avatar
So a muffler that can pass a similar amount of CFM as the engine wont cut it as the gasses are super heated and volume has increased.
88 Carrera
Old 10-10-2006, 07:13 AM
Accoustics
Collector design
John is right on target here,....
All four factors are just as critical as the muffler internals and dimensions.
A note about race mufflers,......we did some testing a few years ago between a Flowmaster Series 80 muffler and a similar Magnaflow. On smaller engines, there was an 18 HP difference from 3K to 7K with a FAR smoother air/fuel curve. Outwardly, they looked almost identical except for materials.
IMHO, there are more bad mufflers out there than good ones so one should do some dyno tests with the specific engine being used since that too, is a big variable. In many cases, its not a "one-size-fits all" sort of thing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-10-2006, 08:48 AM
pmajka's Avatar
So, who had better performance magnaflow or flowmaster?
88 Carrera
Old 10-10-2006, 11:43 AM
It depended on displacement, cams, and compression ratio.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-10-2006, 12:29 PM
Wider is Better
wholberg's Avatar
Don't forget the normally aspirated cars have about 80% volumetric efficiency, so multiply a theoretical calculation by 0.8 for an approximation of CFM flow.
Wider is Better
Old 10-10-2006, 06:23 PM
A Quiet Boom's Avatar
As I recall from the books I've read exhaust sizing is more a function of maximum HP that it is engine displacement. I used to have a calcultion around somewhere for it. On a street car as well as some lower reving track cars you'll find a little back pressure is benefitial. In an all out drag race engine I've used 4" pipes into 4" two chamber mufflers vs. open headers and seen little difference in ET. I did note that with mufflers the 60' time was a touch less so there's agood chance there was more HP with open headers (4.5") but more traction with the mufflers (about 60lbs near the wheels). When I built the X-pipe for my 911 I went with what I know works well in the 200-250 range for a V8. With two 2.5" Walker Dynomax mufflers and 2.5" pipes onto shortened heat exchangers my 3.0 made roughly 210 HP at the flywheel after converting from rear wheel HP. The downside is the muffler is designed to be used with a tail pipe and I only had room for about 6" after the mufflers so it's loud, I like it but others might think it's too loud. Maybe bell will chime in here as he's both driven as well as ridden in my car. Meanwhile I'll dig up my books and try to find those calculations.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 10-10-2006, 09:15 PM
