Guest
Posts: n/a
Pedal Bushings
I have a funny little click which happens when I depress the brake pedal. The pedal works fine but the click bugs me. In looking at the pedal assembly, it appears as though the click is caused by some amount of slop in the brake pedal to linkage connection just below the pedal pivot point. I saw a set of Weltmeister brass bushings in the Automotion/Performance catalog and was wondering if anyone has done this swap. How involved was the work, any gotchas, special tools needed, etc? Anbody else have a similar click?
Thanks in advance. britt |
Guest
Posts: n/a
Britt, I just performed a pedal bushing rebuild to the Weltmeister bronze bushings you mentioned. Take a look at a post I made entitled "Pedal Box Rebuild". Let me know if you have any further questions and I will try and help. Bill ------------------ William Armentrout 1973 911T 2.7 carerra rs specs www.geocities.com/william_armentrout |
