Poll: Which size Optima Red Top?
Poll Options
steve911's Avatar
Optima Owners - which size are you using (and why?)
Time to replace the LARGE Die Hard with a new battery (battery died last weekend, so I'm due). I've checked the charging system and am getting 13.6 volts across the battery terminals, so I'm pretty sure its just the battery.
I'm pretty much decided on the Optima, but the question is, which size Optima Red Top?
34/78 with CCA = 800
75/25 with CCA = 720
Car lives in the garage and the outside temps almost never go below freezing.
Yes, I've searched and haven't found a consensus on the size.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 10-10-2006, 06:41 AM
Here are some posts of mine...including further embedded posts..on various sizes, options, etc. Largely focusses on Optima...
Battery Replacement in a 86 - Advice Please
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-10-2006, 07:13 AM
steve911's Avatar
Thanks Wil - very helpful. I'd already read some of them in my search. Now I'm trying to get a read on whether I need 800CCA or 720CCA.
RIP Warren
Old 10-10-2006, 08:48 AM
OK.... I went to the Optima web page and other pages inside--->
http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive/starter/technical_specs.html
It seems that the 75/25 is:
- 9.3" Long
- 6.8" wide
- 7.6" High
- weighs ~ 33 lbs.
In contrast, the 34/78:
- 10" long
- 6.8" wide
- 7.8" high
- weighs ~ 38 lbs.
On the one hand...you probably don't need the "bigger" unit ( although fairly equal in size)...due to apparent warm conditions where you live. But the size and weight differences are so small..why not get the "normal" , conventional 34/78 Optima that seems to be standard fitment for our 911's?. I don't think you're talking a racing or super-lightweight conversion..are you?
- Wil
EDIT- by contrast, the 49/93 "big honker" stock battery was ( IIRC) about 2" longer and weighed-in at closer to 50 lbs or so.
Wil Ferch
Old 10-10-2006, 09:21 AM
19 years and 17k posts...
azasadny's Avatar
I had two Optima red tops die in a year and switched to the Odyssey 680MLT which is only 15lbs and 680CCA. I haven't had any problem since...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-10-2006, 09:48 AM
randywebb's Avatar
in a few years you'll be able to sneak up to a new Prius III and rip out the Li ion packs...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-10-2006, 11:33 AM
