My other ride is a C-130J
RNajarian's Avatar
Oil Viscosity
Hello All
I recently had a Quality Shop (VERY familiar with 911s) do some work on my 1983 SC.
They replaced several oil lines and also regreased the number eight bearing.
I replaced the lower valve covers.
The oil leaks from the valve covers seem to be gone. However there are still leaks coming from what I fear to be where the Case comes together. (Actually these appear to be new leaks)
The leaks occur only when the motor is hot/warm
My question. Would switching to a more viscous oil slow down the leaks? Is that even a good Idea? What oil viscosity would be recommended?
Of course The temptation to put in the stop leak is very great but I have not done so under recommendations from this fourm
Thanks Gang
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 10-20-2006, 10:34 AM
what oil are you using??
I would not put synthetic oil in that motor but would stick with a good 20/50
for summer and maybe a 10/40 for winter
Old 10-20-2006, 10:45 AM
RNajarian's Avatar
No I am not using Synthetic. I believe the weight is either 10/40 or 10/50.
Is there something THICKER which may help I wonder
Old 10-20-2006, 11:09 AM
My '71 leaked less (both while parked and driving) when I switched from 15W40 to 20W50. Similar experience with aircooled Beetles.
Cheers,
John
Old 10-20-2006, 11:32 AM
RNajarian's Avatar
That is good advice. Thanks. I will call the shop and ask them what Oil they used when the did the oil change
Old 10-20-2006, 11:53 AM
