any idea what this is? (pic)
Every time the throttle cable is down all the way it has contact with this device, kinda like a button (circled below) anyone know what it is or does? Thankshttp://forums.pelicanparts.com/uploa...1160583559.jpg http://forums.pelicanparts.com/uploa...1160583575.jpg
WOT switch. idk much about porsche systems, but usually it disregards the o2 sensors and go into "open-loop" mode for most performance.
Flux Capacitor
WOW, interesting plumbing!
It's the bracket that holds the cruise control cable.
whats all that silver and plastic stuff running thru there? could you post a pic a little bit back so I could see the whole engine.
thanks... |
Looks like the timer for the dryer.
I know where to look for a hose clamp ;)
all jokes aside, im not sure where all those hoses go. I backdated my heater and tossed the junk from my air pump a long time ago. I just dont remember it being that busy in there! |
A mounting bracket for part of the cruise control
Steve |
WOW
If that engine is running do you realize that you ARE MISSING the the bolt that holds the fan shroud/alternator in place! I would not start the car until you bolt that correctly Steve |
I'm with Dean. I'd guess its a WOT switch.
Glenn |
It goes to the water pump...............
| All times are GMT -8. The time now is 10:47 AM. |
