-   -   1st engine drop (and I did it single handed). (http://forums.pelicanparts.com/porsche-911-technical-forum/309136-1st-engine-drop-i-did-single-handed.html)
HFR_Racer 10-11-2006 07:25 PM
Like a walk in the park everyone..
Now I'm wondering if I can get it back in myself as well. Sorry.. No pics yet..
Enjoy,
HFR_Racer
Hugh R 10-11-2006 08:02 PM
Let me be the first to say congrats! I pulled mine for the first time by myself last xmas break. Not terribly hard, but not like any other engine I've ever pulled. I used an engine hoist to lift the rear of the car versus getting it way up in the air with jackstands. Much safer I thought, and I had the engine hoist so I didn't need to buy the RV jackstands. Gotta love them Targas!
Evans, Marv 10-11-2006 08:52 PM
I'll be the second to congratulate you. Putting it back in solo isn't as easy, but doable.
MattAlpha 10-11-2006 09:38 PM
Congrats!
I have this looming in my future...sometime in the next year.
All of the threads here will help guide me through it along with the Bentley manual and Wayne's books.
-Matt
sww914 10-12-2006 12:43 AM
Just don't be afraid. Even if the next to worst thing happens- you drop the engine on the ground- usually nothing gets very messed up. If the worst thing happens- you drop it on yourself- things get more messed up.
JohnJL 10-12-2006 02:06 AM
always throw the wheels under the car when jacked up for xtra safety. I put mine back in, awkward but nothin' but leverage involved.
spikesdad 10-12-2006 03:57 PM
Wow Hugh!!
That's a great idea.
I have a engine hoist.
But I have a question.
Where exactly did you pick up the rear of the car?
Hugh R 10-12-2006 04:13 PM
Take out the engine mounts and make a plug with a lifting eye hook that is bigger than the engine mount holes and mount underside. DON"T lift through the mounts themselves, they'll probably rip out.
HFR_Racer 10-12-2006 07:01 PM
Thanks for the kudos..
Thanks everyone for the congrats...
I have a helper to put it back in tomorrow.. I just dropped it to clean it up, check for the common leaks, adjust the valves, etc..
I think I may need a shifter shaft seal and that's about it. I'm not seeing any leakage between the jugs and block so I hope this means no broken head studs on the exhaust side.
Enjoy,
HFR_Racer.
Shuie 10-12-2006 08:56 PM
If you didn't already use one to do the drop, go buy an ATV jack for the reinstall.
HFR_Racer 10-15-2006 06:03 PM
All is well.. No broken studs..
No broken head studs found at 60k miles. Valves adjusted. Engine and transmission cleaned up and shifter rod seal installed.. Time to re-install..
HFR_Racer
Zeke 10-15-2006 06:18 PM
I think I understand you, but could you say that again differently? Are you saying you held the motor up while you replaced the bolts with forged eye hooks and then put a chain between them to lift the rear of the car? If so, did this not put an undue lateral strain on the mounts?
Maybe I'm lost here. :confused:
