Sources for LED light bulbs for '89 911
Does anyone know where (in North America) I can order the various LED bulbs to replace my incandescent bulbs for turning signal, back-up, brake/tail lights? This is for a 1989 911.
Thanks!
Paulo
Old 10-12-2006, 12:03 PM
Me like track days
Craig 930 RS's Avatar
I've never seen the running/brake combo bulbs anywhere..........been wondering about them.
FWIW the whole bulb deal has been discussed at length here many times
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-12-2006, 12:08 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
I have all my rear lights as LED, got the bulbs from a supplier in the UK, and then spent a week upgrading the indicator relay to work with the LED bulbs for the indicators...
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 10-12-2006, 12:25 PM
I don't know that you can simply change out the incandescent bulbs with LEDs. I have LED tail and brake lights, but they're in a lightweight RS taillight unit, and I know the LEDs have some kind of small circuit board embedded in each unit.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-12-2006, 01:16 PM
Me like track days
Overall, not worth the effort and inferior light overall (yep) - gleaned from a ton of past posts.
Old 10-12-2006, 01:33 PM
True enough. I expected the taillights to be a lot brighter. Even went and installed a CHMSL to help. The instrument lamps are simply...well, a cool blue.
Stephan Wilkinson
Old 10-12-2006, 01:48 PM
There are a myriad of LED brake/tail light lamps on the market. Some are brighter than others. Some LED brake/tail lamps have 9 LEDs; some have 40 or more. Do a Google search under "automotive LEDs" or some variation of that.
A few links:
http://www.lunaraccents.com/safety%20accessories.htm
http://www.webbikeworld.com/r2/led/led.htm
http://search.ebay.com/search/search.dll?soincludewords=led%20tail%20light
You wll have an issue with the directional flasher relay because it works on current load, and the LEDs use very little, but there are solutions (special flasher relays, add'l load circuits).
Sherwood
Old 10-12-2006, 02:40 PM
Yeah, I looked at those before installing mine. Easier installed in a motorcycle than a 911, though certainly just about anything can be fabbed up. Having gone this route, I have to agree with Craig911...unless you've actually installed these lights rather than looked at them on the web and can assure me they're bright, not just that they have lots of LEDs.
Stephan Wilkinson
Old 10-12-2006, 03:10 PM
Not many LED brake/tail lamps are DOT-approved except for the OEM assemblies on new cars. The aftermarket bulbs are bright enough on-axis. Off axis is what is questionable with some of these, and I suppose the reason DOT won't ok them. The latest versions I've seen mount some of the LED array at an angle to increase off-axis visibility.
There are two advantages to using LED bulbs; lower current flow and very fast response time, much faster than an incandescent bulb. At 60 mph, the extra warning time (in milliseconds) for a trailing vehicle could mean the difference between stopping a few feet before or a few feet after your rear end.
LED lamps are available in a regular 1157 base configuration. If you have the room, they install like any bulb. If there's a question of space constraints for a 92 LED bulb, measure twice before ordering.
Some are somewhat pricey though.
Sherwood
Old 10-12-2006, 03:50 PM
coolcavaracing.com
Kroggers's Avatar
As I said in my post above, I did this during the summer, and I have had no problems with them. When testing, they were just as bright and I have past one yearly vehicle test this year with them. Here is a picture with the rear LED lights turned on in the sun.
My main reason for this conversion was reduced current and increased response time.
I also did the relay replacement for the LED turn signals. I did a write-up on here for the solution...
Old 10-12-2006, 10:01 PM
Me like track days
What was that link? Can you post it -
Old 10-13-2006, 06:58 AM
coolcavaracing.com
Kroggers's Avatar
I solved the LED indicator problem!!
Old 10-13-2006, 07:11 AM
GeorgeM's Avatar
www.superbrightleds.com
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 10-13-2006, 08:21 AM
