LinkBack | Thread Tools | Rate Thread |
Me like track days
IMO, one of the most unsafe items on a 911 is how late the damn brake light (fluid pressure) switch activates the brake lights.
Ridiculous. Even installing a new one doesn't seem to help. Is there any other switch that activates earlier? Or any mod that can be done? I'm tired of the relatively dim brake lights PLUS the high effort/quick stops required to activate the brake lights..... Ideas?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Some one did a thread about adapting an earlier mechanical style to a later car, try a search
Driving member
One of the members installed a switch on the pedal. I think he bought most of the parts from JC Whitney. May be able to do a search.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Me like track days
Tried the search - zip.
Ideally, a switch with a lower activated pressure is the best solution.
Me like track days
Found this from early this past summer:
Installing mechanical switch for brake lights, with pics When searching for "mechanical brake switch"
Administrator
There's a product for motorcycles that adds an additional brake light and uses a mercury switch. I'm always leery about home-made fixes to something as important as brake lights, but a redundant light could be added as a safety feature.
http://www.brakeflasher.com/cycle.htm (Only downside? A flashing brake light is going to be more noticeable to law enforcement when you see them and decide to quickly slow down.)
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Driving member
Craig, you found the one I was refering to. I feel like if it could be reliable enough it would be much better to take the hydraulic switch out of the loop.
I think the switch setup in almost all other cars and even some years of ours is a better solution. I wonder if anyone has taken one out of a 911 that had that kind of switch and retroed it in. That might be an option.
Interesting! And I thought I was the only one who had this problem. Even installed a new switch, no improvement, was beginning to worry that I had something faulty.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
You could also use the cruise switch which is already activated by the brake pedal
The cruise switch is a good idea. Those little f'rs cost me 1/2 a track day once when I had no brake lights. Two new switches are now std spares for me.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
My Mechanical switch is still running fine. Gotta love it.
And now, i remember the other reason to Mech the switch.... Quote:
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
Oh, and the Photos that WON posted look just like mine....
I agree, same problem with mine, it doesn't come on as lightly as I use the brakes sometimes. Also, having big brakes and weight reduction and wider tires, the thing slows down real quick, and I don't want to have to stab them to get the lights to come on.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
Any switch can go bad, there can also be issues w/ the old mechanical switch when it is used w/ a big m/c and calipers w/ smallish cylinders. In that case there isn't enough travel to actuate the switch under light braking.
I had the same problem with my 84 carrera. I used a brake switch that turns on, on release, rather than having to be pushed. I made a small L bracket and it screws to the plywood foot board. The switch pushes against the the pedal. Soon as you push the pedal it activates the brake lights. My 740 Turbo Volvo has the same setup from Volvo. If interested I will take some pictures and give you the part number.
Me like track days
Sure, that'd be great to post the part number - I need to fab something like has been mentioned here.
Somebody on the thread referenced by Craig911 claims that the slow-brakelight-reaction problem is caused by installing the brakelight switches without pre-filling them with brake fluid, which leaves an air bubble inside them, and that that's what is causing the slow reaction.
Does anybody have any comment on that? Can we solve all our problems wimply by removing the switches and in effect bleeding them? Certainly easier than kludging up J C Whitney contact switches... Oh, and thanks, Jack Olson--just bought a couple of those motorcycle mercury-switch LED arrays. We had a Boxster destroyed by a Ford Excursion last summer, damn near killed my wife, so I'm now paranoid.
Me like track days
WOW. If you have not looked at the setup that JackO referenced - it is worth a look.
I am going to purchase 1 or 2 - great idea.
The switch is a CarQuest part # SLS66. I used the wires from the pressure switch, can be reversed easily anytime.
run them in parallel
i would wire them in parallel with the original switches then either /or will bring the lights on
1975 911S Targa Silver Anniversary Edition |
