Unregistered
sammyg2's Avatar
damn mice
I was just out on the garage and glanced under my SC. There under the joint between the engine and transmission was a scattered pile of black stuff, looks like little tiny balls of black foam rubber, the kind of stuff you would find wrapped around a roll bar.
I figure a mouse was chewing on something in there.
Before I jack it up and start poking around, and guesses what he got into?
Needless to say there will be a few "samples" of peanut butter in the garage tonight with a special surprise.
Old 10-14-2006, 01:07 PM
Jim Smolka's Avatar
They must be delt with before they decide that the top of your motor is a great place to build their den.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 10-14-2006, 01:12 PM
moth balls also work as a good repellant.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 10-14-2006, 02:03 PM
Licensed User
Shuie's Avatar
I just heard what sounded like a small explosion while trying to start my 3.2 conversion. I rushed to the back of the car and discovered a mangled and broken rat on my intake shroud and what looks like oil (probably rat guts) oozing out of one side of my fan housing. I'm so focking pissed right now. I've never had the mice issue before. I can't even tell for sure if he got blown out of the airbox breather or if he got smashed in the fan.
Old 10-14-2006, 02:45 PM
poorsha's Avatar
Stuffed into the seam between the engine compartment and the interior you will find some black foam material.
My guess it that it is simply starting to deteriorate.
I removed mine.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 10-14-2006, 04:52 PM
This can be a very serious issue. I work for a lot of dealerships and mouse damage common. For whatever reason they like to chew wires along with building nests. So if you don't want to risk that take it seriously
Thanks,
Chris Jacob
85' Carrera
Old 10-15-2006, 09:11 AM
Immature Member
dentist90's Avatar
Maybe just the sound deadening pad against the firewall?
( I think this is what poorsha was describing)
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 10-15-2006, 10:46 AM
The best cure to all of this!
Drive the fr!kk!n thing!!!!!!
They're not stoked about moving house....
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 10-15-2006, 05:14 PM
