Newbie oil change mistake.
I did my very first oil change today and boy do I feel proud and manly. Saved $100, only took me 2 hours. Wife is semi-understanding of how I spent my Sunday afternoon.
Jacked up the left rear to make it easier to get at the engine case plug. One tip for uber-newbies like me. I had some fancy air tools that I got cheap. Can't use 'em to take off the engine case plug. Jams up against the heat exchanger as the drain plug comes outand almost couldn't get the bloody air rachet off the car! Ready to try a brake fluid flush next! I wonder what new mistakes I can make. Lawrence
1985 911 Coupe Black 1985 911 Cab GP White (killed) |
Make Bruins Great Again
Congrats. Working on your car is a bonding experience that makes the driving that much sweeter.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
If using a pressure bleeder, pumping brake fluid out the reservoir vent onto the ground because you didn't plug the vent.
If using press the pedal method, stroking the MC seals into a dirty, rusty section of the bore where the seals become damaged and subsequently leak. Both methods, breaking off or rounding off the flats on a frozen bleeder valve. |
Insert Tag Line HERE.....
air rachet on oil drain plug?? uh oh....
Marc |
You do not have permissi
Check oil level when running.
Very little anti-seize on lugnuts(curved section) and use hand torque wrench. Learn jack points and use wood block. Only anti-seize used on the plugs should be Locktight Graphite 50 (high conductive).
Meanwhile other things are still happening. |
Re: Newbie oil change mistake.
Don't use air tools as a novice, is all I can advise. You can't feel what you need to feel as you remove and tighten various fasteners and plugs. Air tools are for working on trailers, AFAIC. Or Chevy V8's. (I've had/have both) |
Thankfully the tools don't have much torque. Just faster. I used a regular rachet to "crack" it. I know better for next time.
Lawrence
I patted myself on the back after my 1st oil change....Kept patting until I drove it and put oil all over my garage floor......
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Re: Re: Newbie oil change mistake.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
Me too, I will (plan to) do clutch/brake fluid bleeding next weekends.
Fat butt 911, 1987 |
A 1/4" or 3/8" drive air ratchet is handy to have. I use the less awkward-to-handle 1/4" ratchet for most fasteners up to 13mm (head size) or so. Use manual force to break the fastener free - the small air ratchet doesn't create much torque anyway, then pull the trigger to spin the rest of it off. Saves much time iif you have several fasteners.
Save the air gun for rapid removal of fasteners. When installing, start the threads by hand, use the ratchet to spin the fastener until it seats, then final tighten by hand. Or take your time. Some find rotating nuts and bolts relaxing. Sherwood |
11-piece open/box end metric wrench set from Sears. Leather work gloves. Take your time. Once you get the spillage on a 911 oil-change below one quart, you're pretty much a pro.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
I did pretty well on spillage until I tried to pour the old oil into the old jugs. Lost about half a litre (quart).
Lawrence
Not to get off track here, but what brand oil drain pan are most of you guys using? My tried-and-true Pep Boys black plastic one - the kind that acts as a reservoir to store the dirty oil until you take it to a recycling station - I don't think it has enough capacity. Isn't min capacity for a 911 without an external oil cooler like 12 or 13qts? i.e. 3+ gallons?
Dan in Pasadena '76 911S Sahara Beige/Cork |
billroth,
I hope you drained 'both' the engine and reservoir. Each has drain plug. Also wipe the little magnetic tips with a clean rag. Use the Mahle OC-54 filter on the 1985 (I did not know that for awhile.) I also did new brake pads/rotors. I did one wheel at a time, seating the brake pad after the flush (using clear jar and clear tube ~3feet). End of tube in jar must be cover with fluid as the process will suck some back in. When you compress the caliper, the brake fluid backs into the brake reservoir. So be careful not to overflow it. That's why I do one wheel at a time. Basically I pump and check, repeating until clean fluid is flowing in the tube. I do the other side, same process. If new pad then they must be broken in (bedding) per mgf recommendation. Also I have some plastic caliper I use to check rotor thickness. I never turn disc brake rotors but just replace them on second set of pads. Last edited by glenncof; 10-17-2006 at 02:00 PM.. |
"I did one wheel at a time, seating the brake pad after the flush (using clear jar and clear tube ~3feet). End of tube in jar must be cover with fluid as the process will suck some back in."
This is the procedure I suggest. However, instead of curving the tube into a jar, point the open end upward. If the tube is long enough, the end will be above the height of the MC reservoir and fluid won't overflow (liquid finds its own level). This creates an extension of the hydraulic system for that caliper. With the bleeder screw open, you can pump the brakes all you want (careful with pedal travel) and/or rap the caliper with a mallet to dislodge bubbles. Fluid will exit and enter the caliper with each pedal stroke, or just let it the system sit and wait for air bubbles to escape. If the tube becomes too full from working the pedal, point it down momentarily and empty the excess into a jar. Sherwood |
I cut down a five gallon bucket so that it fits under the oil tank.
Never spill a drop.
Silver 1980SC Euro coupe |
I use Rubber Maid dish washing tubs, small and large for various oil drains. They also store the oil change tools/funnels. I hang on to 1 gal. plastics jugs and use them for recycling oil. My garbage company picks them up curbside if screw-on lid. I go to a recycle dump with filters and oil also.
BTW, don't let anyone tell you 3000 mile oil changes are bad for environment. Recycled oil gets refined and reused. What is bad is poorly maintained vehicles that don't live long lives and have higher pollution. Think about the energy consumed to make a vehicle. Last edited by glenncof; 10-17-2006 at 02:13 PM.. |
