8 Pin CDi
Hi, I have an 8 pin CDI from an early 930.
Does anyone know the pin out for this or have a wiring diagram? Thanks Geoff. |
Geoff,
Here is the Permatune tech page for their 8-pin model that shares the pinout with the Bosch 8-pin CDI ... the pinout can be used, but not the bench checks: http://www.permatune.com/930902tech.html
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
you can actually use a 6 pin in place of that if you use the proper plug and omit the two wires that go to the suppressor. compare wiring diagrams and you'll see how to do it.
