Turbo fuel pump wiring
Can anyone help with the correct wiring layout for running the 2 fuel pumps maybe a wiring diagram for 3.3 turbo.
Old 10-16-2006, 11:03 PM
David's Avatar
What exactly are you looking for?
Old 10-17-2006, 08:25 AM
I am trying to sort out the wiring for the relay panel which fuse/fuses to use and how to get power to the relays etc
Old 10-17-2006, 02:40 PM
David's Avatar
The two turbo relays run off the same signal (blue +, brown/red -) which comes from a relay which is turned on by the air meter contact. The over boost limit switch cuts power to the air meter contact relay on over boost.
Old 10-17-2006, 02:54 PM
pm sent.
Old 10-17-2006, 03:14 PM
