911SCfanatic's Avatar
are wires 30, 87, 87a 12 gauge on an OEM relay socket?
Doing the headlight upgrade and I'm hell-bent on using the OEM relay sockets for some reason. From my thread reading, I need 12 gauge wires to and from 30 and 87...does the OEM sockets use 12 gauge wire? At $51 a pop, I wanted to make sure before buying them. TIA.
Bill G.
'68 911 Ossi Blue coupe
Old 10-16-2006, 12:25 PM
304065's Avatar
No, more like 16
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-16-2006, 01:01 PM
ianc's Avatar
If you want to be a mental case (and save a few $$$), you can rewire the stockies. See here:
My H4 Project (Long w\ pics)
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-16-2006, 01:06 PM
The short length [couple of inches] shouldn't be an issue. Just solder the 12 gauge to it. There isn't 12 gauge wire inside the relay. Its the 6 or 8 foot run of 16 gauge that makes for melted wires.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 10-16-2006, 06:39 PM
Relays have a current rating based upon the size of the wiring and contacts. Exceed the ratings at your own risk.
Be smart, either find out the current rating of the stock relays or get relays that are rated for the current.
You might find the relays are of sufficient capacity to run one light at a time. Then you are looking at 4 relays. 2 for low and 2 for high.
Hey, it's only money, green paper with old men on the front.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 10-16-2006, 09:47 PM
ianc's Avatar
I believe the stockies are rated at 30A,
ianc
Old 10-16-2006, 09:51 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
This is precisely why I used six (yes, 6) commonly available 30a relays to isolate each filament, which reduces the amperage through each relay. It also makes troubleshooting easier, as well as eliminating full lights out during a failure. Search my username and Headlight Relay for threads.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 10-16-2006, 09:57 PM
