David's Avatar
I can't open my gas filler door!
I know this has been asked before, but I can't get the search engine to find it.
I haven't opened my gas filler door for over a year and now I can't open it. The pull has full spring tension and it sounds like it's doing something. I've pushed on the door while pulling the handle and that doesn't help either. Thanks for any help.
Old 10-15-2006, 03:17 PM
Thread a loop of nylon fishing or weed eater line through from both sides to trip the latch without scratching the paint
Old 10-15-2006, 03:21 PM
David's Avatar
Thanks, that worked like a champ. The cable's not working so I've got something else to fix.
Old 10-15-2006, 03:27 PM
Jeff Alton's Avatar
Oh and be careful if you take the latch out, what fun it is(n't) to put the little spring back in. Taught my son a whole new vocabulary while working on that little F$$k%r......
Cheers
www.turn3autosport.com
Old 10-15-2006, 06:24 PM
Hopefully this doesn't add another year to your project. I'd like a ride someday.
Old 10-15-2006, 06:55 PM
Sleep Deprived and Grumpy
jwernquist's Avatar
K Thx. Strange I only have 4 messages in my box. I tried to send you a pm first and It told me yours was full!
JW
jwernquist@wi.rr.com
262.215.6547
Old 10-15-2006, 07:37 PM
David's Avatar
This should probably go on the "what's the stupidest thing you've ever done" thread. I guess when you don't drive your car for 28 months you forget were things are. I was pulling on the trunk release and since the trunk was wide open, nothing happened. Doh! At least I know how to open my fuel door if the cable ever breaks.
BTW, if all goes well I'll try to start her tonight!
Old 10-16-2006, 04:59 AM
THAT is funny !
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 10-16-2006, 07:56 AM
defcon65's Avatar
I still catch myself pulling the front hood release when I have to check the engine. I've had the car for a year now. The engine's in the back, BTW.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 10-16-2006, 11:29 AM
pwd72s's Avatar
And the engine lid release is located.....
Old 10-16-2006, 11:33 AM
DG624's Avatar
Since the topic came up has anyone repaired the gas door hinge? My door does not open unless I pull it open due to rust I think but mybe something else. Has anyone removed the pin for the door? Do I have to unscrew the latch or is there another way?
Old 10-16-2006, 12:19 PM
Ken911's Avatar
you have to remove the three screws holding it in and remove the whole door then in can be cleaned and the spring tightened while it's out
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-16-2006, 01:20 PM
Driving member
jester911's Avatar
3 small allen screws to remove. Access inside the wheel well. You can turn the wheel enough to get room but it is much easier with the wheel off.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 10-16-2006, 01:24 PM
DG624's Avatar
OK, Jerry and Ken I will try that...its always the simple things that I put off.
Old 10-16-2006, 02:16 PM
jjwood's Avatar
On a related topic...has anyone converted their long hood gas filler to a late model style. My Boxster just requires a push against one edge to open. Sure wish my long hood could do the same. The old cable style release is a PITA!
Jeremy
1971 911 Wide One 2.7
2012 911 Cabriolet
2011 Cayenne S
Old 10-16-2006, 03:36 PM
You do not have permissi
john70t's Avatar
If you thought replacing the drivers-side hood latch was a pain, wait 'till you replace the spring in the gas door release mechanism. Oh yeah.
The trick I used was to assemble it with a piece as a surrogate pin, press the whole thing in and slide the pin in while holding it, but there's probably an easier way.
Old 10-16-2006, 03:42 PM
DG624's Avatar
John, the door seems to be sticking because the hinge is rusting...I will have to remove the pin but how is that done without destroying the door? I think driving it out is the only option but I don't want to bend the door. This is the type of repair that is never covered in repair manuals.
Old 10-17-2006, 10:40 AM
