ROWSC
Guest
Posts: n/a
Are genuine parts worth the cost?
When it comes to things like a turbo tail, is it worth holding out for a used factory tail or are the reproductions of sufficient quality?
Rich
Old 07-19-2000, 09:19 PM
Andras Nagy
Guest
Posts: n/a
Rich:
The only caution is that some are fiberglass, some are carbon, and some are metal.
Since there is no issue of dis-similar materials in close proximity or bonding to each other, the choice is really up to your preference and your pocketbook.
Just be sure that you choose a reputable manufacturer, since quality and accuracy of reproduction is what cost more than the cheaper ones.
BTW, if originality is important to you, stick with a used factory unit. They were designed by the same engineers who designed the rest of the car, and should thus fit much better. Hope this helps.....Andras
Old 07-20-2000, 06:22 AM
H20911
Guest
Posts: n/a
Rich,
I have to agree with Andras on this one and although I don't think that you have to stay with stock, the most important thing should be the quality (fit and finish) so I would go with the used factory turbo tail if you can . I have seen some "So-So" reproductions of the turbo tail and even have a "So-So" tt on my car now
It will eventually be replaced by an extended GT-2 wing When that time comes though, I will be looking for a quality product (read as not cheap) just like you.
Good luck!
s
Old 07-20-2000, 07:49 AM
