Danskeren's Avatar
Tail light unit - How do I disconnect wires ?
Hi,
I trying to take out the tail light unit on my 911S from 73. But the wires are all black covered with a thick layer of Dinitrol.
How/ where are the wires connected ? and how and where do I unplug the wires ??
Any help much appreciated - especially pictures showing what I should expect under the Dinitrol. Thanks.
Best regards
Peter
'73 911S Targa black - original
'73 911RS clone 3.6, non-sunroof Coupé
'01 Volvo V70T5 - 320bhp
Old 11-20-2006, 10:23 AM
poorsha's Avatar
The wire connects with a multi-pin round plug to a receptor in the body.
Look inside the engone compartment and you will see the wiring harness fitted to a round connector in each corner.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 11-20-2006, 10:51 AM
Danskeren's Avatar
Poorsha - thanks. Yes I see the connector inside from engine comp. Is it the same connector type on the outside ?
Peter
Old 11-20-2006, 11:13 AM
poorsha's Avatar
Peter,
the plug in the engine compartment will put out.
The tail light has a female plug that is press fitted into the body.
97 328i Convertible
Old 11-20-2006, 07:52 PM
