-   -   SC running "too damn hot": Mechanics stumped, So am I ! (http://forums.pelicanparts.com/porsche-911-technical-forum/310553-sc-running-too-damn-hot-mechanics-stumped-so-am-i.html)
Deschodt 10-29-2006 05:37 PM
Ok, not so much bumping this thread as reporting on the final "to-dos" from all of your ideas...
- New thermostat to the main cooler (engine mounted)
- Verified the flow to the front cooler
- Verified the front cooler is not obstructed = similar readings up/ down/ right/ left of the cooler
- Verified the oil lines not crimped, temps difference 20 to 30F between inflow and outflow with the fan on
- Verified timing: At Idle: 3 BTDC
At 3000 RPM = 18 BTDC
At 5000 rpm = 20-22 BTDC, matching the specs for an SC engine to the letter (what's the 36 degrees advance at 6000 rpm, mentioned by Dr Steve for? Non vacuum line distributor cars?)
- Belt was slipping a little and jumping a little at high rpms, put fresh one on the car
- New temps activated ft cooler fan instead of hand switch
- Put in a new temps sender tonight, and verified the old one worked as a charm ! If anything it read a few degrees low, not high !
Results: not much. The automatic fan is a bit better as I can set it up to engage at lower temps and not "forget", so in town I am running 90C or thereabouts. On the freeway, it's back to 225-235F in no time, the speed and turbulence negates the airflow from the fan...
I could not check for rat remains on the cylinder fins, I can barely see what's behind the fan, no mirror combo will get me past the fan... My last options are the used crank pulley (134 mm dia.) to increase air flow by increasing the fan speed, and some more barricading of the front cooler so that air has nowhere else to go but through it!
Slightly dissapointed to have gained very little after all that ! ;-(
ras911 10-29-2006 05:53 PM
Did Any one suggest the ,,,,,,,,Cool Collar?
http://forums.pelicanparts.com/porsche-911-technical-forum/7592-cool-collar.html
Hope you get that sorted out . I had a red one that liked to run hot , drove it 3 seasons in DC
Bob SmileWavy
Duckworth 10-29-2006 05:58 PM
That's a crushing amount of time and effort for little-to nothing in return....
Your troubles are most unusual. What I recall very well on my '82 was that even at 105 F - as soon as the car hit the freeway no matter how hot it was - the gauge always backed itself down to a healthy reading. It only had a trombone cooler - which very seldom ever got activated by the thermostat.
Wonder if a motor 'swap' or drop would reveal the problem.
________________
'82 Targa - sold
'80 928
Deschodt 10-29-2006 06:03 PM
Well, it does have 170K miles, but I am not sure how being possibly "tired" translates into hot temps. Also, it was already doing this 70K miles ago ! And it's still running strong !
This one has stumped 3 mechanics now, not the worst ones either (some famous shops from San rafael,CA - and now my local wrench in FL)... If I ever figure it out I'll have to write a book !
dickster 10-30-2006 12:36 AM
Hi
It is worth checking the sump plate as others have suggested.
Good luck!
Ps You could move to a colder climate! (from the cold uk)
Noel 10-30-2006 02:57 AM
I still think you need to remove the fan and have a proper look at the top of the cylinder fins and most importantly on top of the on engine oil cooler to verify that air is flowing through. This is the most likely cause IMO.
scarceller 10-30-2006 05:42 AM
I agree, seems like you have checked everything else. You need to be sure air is flowing through the cylinder fins and the engine mounted cooler. I think it would be wise to inspect this. As mentioned above remove the air fan as well as the covers to the left and right of the fan to get a good look at the top of the engine case as well as the air fins. I also posted earlier to be sure no one installed the air diverter sheet metal betwen the cylinders backwards, I had a 75 2.7L that someone (prior to me) had done this.
Deschodt 10-30-2006 05:58 AM
Ok, I will unbolt all that stuff - not sure what the air diverter should look like if properly mounted. Pictures anyone ?
I never considered that one carefully as it was for early 78 SCs, mine is 83 !
Craig 930 RS 10-30-2006 05:59 AM
Greg -
Please take some pictures on the oil cooler setups - in. under, around, and post them -
scarceller 10-30-2006 06:56 AM
Picture of access plates
http://forums.pelicanparts.com/uploa...1162223461.gif
http://forums.pelicanparts.com/uploa...1162223490.gif
Picture of Air Deverters/Baffles between cylinders
http://forums.pelicanparts.com/uploa...1162223720.gif
Steve@Rennsport 10-30-2006 07:36 AM
Greg:
IMHO, you should find someone with a distributor machine and have your dizzy checked for full advance and vacuum canister operation.
It looks like you have retarded timing at 3K to 6K and that certainly makes these engines run hotter than normal.
Deschodt 10-30-2006 11:34 AM
Steve, thanks for that, but the specs book for the SC says that with the vacuum lines off and plugged, those numbers that I am getting are EXACTLY the numbers I should see...
I quote: 80-83 SC 5deg +- 2 BTDC at idle , vac hose disconnected
21 +-3 deg at 6000 rpm (vac hose disconnected)
That is -exactly- what I get ! I figured that was for distributor without a vacuum system? What is the deal there ? please ! ;-)
I don't understand how to reconcile the numbers in the manual/bentley etc with that 36 degrees number...
I don't doubt you - I know better, andI'd love for this to be the problem, but it does match the manual, what am I missing here ?
Steve@Rennsport 10-30-2006 11:58 AM
Greg:
There are plenty of documented errors in the Bentley manuals so I'd not take everything inside them as gospel.
I WILL tell you that 21 deg at 6K is very retarded and results in excessive engine temperature. Thats a good number for a twin-plug motor,...:)
Deschodt 10-30-2006 12:10 PM
Well, it's also the numbers on the porsche factory charts...
But Ok, deal !! I will advance it more so that it reaches 35 or so, that might mean a lot more advance at idle as well... I will report on results and cross my fingers that does not break anything...
I just wanted to be sure you really meant it, on that model year, with that distributor! But Steve Weiner beats Bentley, in my book ;-)
By the way, vacuum lines pluggedf or connected?
stlrj 10-30-2006 12:23 PM
What is it with the vacuum line connected? Because if that's all you get even after the vacuum lines are connected, there might be your problem.
Cheers,
Joe
Deschodt 10-30-2006 12:39 PM
Well, I just did what Steve recommended ! I now show about 10 degrees at idle (had to lower it) and 35 max advance, regardless of top rpm - it never goes beyond 35deg at 5000rpm, let alone 6000...
I'll run it like that see what happens ! That was with all the vacuum junk connected !
I am baffled by the difference in specs between steve's numbers (frm experience I imagine) and the factory specs !
Stlrj, I don't know what the numbers were with the vacuum connected before this change, since I did it per the book vacuum removed and plugged, but you have what it is now... Would 12 btdc at idle be bad in ANY respect ?
It starts just fine !!
stlrj 10-30-2006 12:44 PM
12 btdc seems a bit high. Do you have a vacuum retard, advance or both ?
aturboman 10-30-2006 12:48 PM
Someone mentioned early on to check the exhaust for restriction, was this done? This is very sound advice since as the exhaust gets older you will often find the cat. convertor breaking down inside and this can cause a major restriction. On air cooled cars in particular this can lead to increased exhaust temps/engine temps. You seem to have covered most of the other bases so far, so I would suggest you get a cat bypass and or borrow another cat and try swaping it out. I'd even try to borrow another muffler as well since they also plug up over time. A customer's SC went 300+K on the original engine but the convertor was toast @ 150K miles when we replaced the chain tensioners. We put in a "test pipe" and it never ran better or cooler after that. Good luck.
Deschodt 10-30-2006 01:21 PM
stlrj, this is a stock 83SC, per the book I have centrifugal and vacuum advance and retard... In other words, no clue !
I read 10 degrees advance now, all connected at idle. The specs are 5+-2 at idle, vacuum disconnected, but 10 degrees all connected now, I don't think it's radical, so let's see what it does... 35 at 6000 is the part I don't know about, I showed 21 before with the vacuum lines removed and plugged. But at least now I am matching what steve recommended...
I also removed the front running light in the bumper and have fresh airflow to the cooler ! Of course if it's dramatically better now, I will be kicking myself because I won't know which of the 2 modifications did it ! ;-) But I am pessimistic by nature, I bet nothing changes !
Turboman, I've been told by the mchanic years ago that my cats have been ...ehhh, gutted by the PO, so there is ZERO restriction there ;-) Then again, maybe I should revisit waht gutted meant and take a look !
Thanks all !!!
stlrj 10-30-2006 11:38 PM
That's what you should be getting with all vacuum lines connected. Are you getting that?
Joe
dickster 10-31-2006 02:00 AM
Never take it for granted that you have the later one! It is worth checking to be sure.
Deschodt 10-31-2006 04:24 AM
Joe, yes I am getting that now (I don't know if I was getting it before, though, since you are supposed to measure 21 with vacuum lines off and I did not remeasure with lines on)..
Ok, results as of this morning :
Bumper "city light" removed for better airflow, and timing advanced to 35 @ 6000 rpm (35 is max advamce anyway, I reach it at 5000).
The car runs significantly cooler, in town and on the freeway, say 20F cooler easy ! The fact that is runs cooler in town where airflow from the front bumper is not as great seems to confirm the timing helps... Also took longer to reach 90C than it normally does, which also helps the distributor cause !
BUT.... Big but !!
If I accelerate hard though 4000 rpm (2nd gear), the car makes a rattle sound that can best be described as a playing card through bicycle wheel spokes. Not sure if that is pinging, but it's a sound that was not there before the adjustment. Almost like an exhaust rattle.
If I accelerate slowly though 4000 rpm, no problem at all...
Is there some other adjustment I need to make to the mixture or something to compensate for the new timing ?
I am tempted to revert back to normal factory specs tonight and reconfirm no noise at that RPM (only when accelerating hard) and retest just the bumper opening anyway... As a service to my fellow hot running SC pelicanites ;-) Opinions welcome !
Deschodt 10-31-2006 05:15 AM
Lovely ! Is it OK to assume that if I don't get on it too hard, I can drive home safely and not do damage ? It only does it under hard load !
stlrj 10-31-2006 05:43 AM
That rattle could be a broken head stud.
Joe
Deschodt 10-31-2006 06:29 AM
Well, too much of a coincidence to be a broken head stud, I think !
The car does not make the sound if I slowly (or normally) accelerate through the RPM range, only if I get on it HARD.
Sounds to me like the distributor is slow to catch up in the middle of the curve! But what do I know ?
Problem: I drive this car a lot. sending it out (generally to the weat coast) will leave me without a car for a month, easy !
Replacing will set me back $930 per pelican's refurb ones ! Options ?
Duckworth 10-31-2006 11:43 AM
Put back the distributor as it was - doubt that's the problem. If the return springs are sticking there are ways to lubricate them.
My '82 was super sensitive to knocking and pinging when I attempted a small increase in the advance. (As you found out also.)
Incredible how easily it would 'ping' in 1st or 2nd as I went from
5 degress BTC - to 8 degrees idle setting. Uhm.., 8 degrees BTC detonates a mild SC motor ??? Anyone explain that ?
One thing I did was scratch a little line next to the nut that tightens down the distrib so that you have an easy reference to put it back to the correct spot when messing around with it or out on the road.
...The time draws near for you to get inside the motor.
_______________
'82 Targa - sold
'80 928
Deschodt 10-31-2006 11:50 AM
Since you're going there... What would you expect to find inside the motor that would cause higher temps ? Broken rings ?
Why would other SCs on this board run fine with 35 degrees advance and 12 at idle ?
>Put back the distributor as it was - that's not your problem.
Well, maybe... But it does run very smoothly and much cooler right now with that advance, pinging excepted ! ;-) I will have the distributor looked at anyway to be 100% sure. It looks lazy to me, because I have no pinging -at all- if I rev the car normally, but it pings if I stick my foot in it - that suggests to me the little dizzy is not keeping up... But what do I know ? ;-) I'd be happy not to have to get a $930 new one or a refurb, that's for sure.
I'm going back to stock timing tonight, and will leave the notch in my bumper open to see the effects in isolation anyway !
911pcars 10-31-2006 12:33 PM
" I will have the distributor looked at anyway to be 100% sure. It looks lazy to me, because I have no pinging -at all- if I rev the car normally, but it pings if I stick my foot in it - that suggests to me the little dizzy is not keeping up..."
Detonation usually occurs under load, moreso than in a low-load condition. That tells me your ignition timing is too far advanced for that rpm, or (here comes the list) ambient temp is too high, unsufficient fuel octane, rpm too low for load, compression ratio too high, A/F is lean, timing too far advanced, engine is overheated, etc. or any combination therof. In addition, all these conditions are interelated. One condition can cause another which exacerbates the symptom.
Sherwood
Deschodt 10-31-2006 12:52 PM
Ok, scratch that then ;-) Thanks Sherwood !
Back to factory settings tonight (Sorry Steve W. I'll still have the dizzy checked for sanity)...
I am losing patience anyway. I have run it 70K miles like this and it's still running, I guess I'll burn this motor down the way it is ! It might be cheaper than to replace all the potential "running hot" causes ! ;-) I think I've done pretty much everything except the dizzy and checking the air diverters between the fins (oh and that sump thing but I don't quite know how to check that one)!
lateapex911 10-31-2006 01:55 PM
Sherwood has it nailed. Factory units from later cars are often constantly adjusting timing on the edge of pinging. Thats what a :"knock sensor" is. Part of the plan! You just took a big jump, so why not try the middle ground??
Also, hi octane fuel ,,,93....helps out a lot. So, make sure the tank is full of the good stuff, then adjust the timing incrementally until the problem stops. It is most likelty to occur at large throttle openings, and usually at lower revs. So in third gear, when you go from a light throttle opening at say 2500 rpm, to wide open will probably bring on the knock condition. Use that, or a similar test and repeat until you find the best combination of advance timing and no knock.
But be carefull!!!!!! Knocking is bad for the engine, and in extreme cases can crack rings and other nasaty things. So, start low ( stock or mid range timing), work up 5 degrees at a time or so,, then back off to the previous setting as soon as it happens.
911pcars 10-31-2006 02:02 PM
Thanks Jake, but it's Deschodt's situation isn't solved yet.
It'd be convenient if audible detonation was the case. Unfortunately, not all detonation is audible. I don't think SC's use a knock sensor. Someone can correct me.
Deschodt,
It might prove useful to summarize the suggestions made and your inspections and remedies to date. Maybe something obvious has been overlooked?
Sherwood
lateapex911 10-31-2006 02:08 PM
Agreed Sherwood, no auto adjust on his car. And you're right, much detonation isn't audible. But i would think that finding the limit, then backing away a bit timing-wise could get him closer and cooler.
audi2.7t 10-31-2006 02:16 PM
After following this thread for a while I have been drawn to a couple of conclusions..
1. The additional oil coolers are unable to compensate for the core temperatures which means the engine is running way hot.
2. The above indicates a lack of initial engine cooling ie. air flow, be it delivery or exhaust. The first thing I would do is make sure that the engine is getting adequat cool air... check the condensor? or even run the car with the condensor off the grille. If the engine is getting cool air, is it flowing over the heads...not just to the heads. Check air baffles, fins, engine bay seals. Blocked condensers, air coolers and radiators that visually look fine are the #1 reason for liquid cooled engines overheating, air cooled engines are the same in principal.
3. Check the entire exhaust for restriction, try a test pipe .
TargaT 10-31-2006 02:40 PM
Are you checking the timing only when it's cool? If so check if it's the same when it gets hot. My timing looked fine till the car got hot, then the timing went all to hell.
Joe
Howard M 10-31-2006 02:43 PM
Besides the very worthwhile check of the air baffles, how about pulling the distributor to confirm free motion of the advance mechanism. Puzzling that you had to "over" advance the timing at idle to get the proper timing at 6000. The over-advanced timing may be contributing to the pinging above idle. If the advance weights were free, proper timing at idle should still yield proper advance at 6K. It's an easy check to make, especially compared to everything else you've done already.
Deschodt 10-31-2006 03:06 PM
Sherwood, and others: thanks! I apologize for the lenght of this thread but I am really determined to get this resolved now !
You asked for a summary, I think I posted one the previous page, but here it is, all updated:
- Mechanic temporarily mounted a front cooler after the fender cooler and blew big air into it, it made no ignificant difference
- Verified timing: As per book, vacuum line sremoved and plugged
At Idle: 3 BTDC
- Bumped timing to Steve Weiner specs - ended up w/ 35@6000 and 10 at idle. Can ran cooler in the morning, but it ran like crap that same evening, hesitating at constant RPMs, and pinging under heavy load. Bacl off the timing to stock. As you said Iam not a human knock sensor, better safe than sorry !
- Belt was slipping a little and jumping a little at high rpms, put fresh one on the car, all good now - zero results.
- New temps activated ft cooler fan instead of hand switch - it helps at low speeds - temps stays at 90C (first white bar) but makes zero difference at freeway speeds.
- Put in a new temps sender and verified the old one worked as a charm ! If anything it read a few degrees low, not high !
- Opened the front bumper (removed what is a turn signal for you guys - it's a running light on my car for some fortuitous reason) for airflow : bubkiss, nada, same difference.
Results: not much. The "automatic" fan is a bit better as I can set it up to engage at lower temps and not "forget", so in town I am running 90C or thereabouts. On the freeway, it's back to 220-230F in no time, the speed and turbulence negates the airflow from the fan, I think...
- The cat is as good as empty so it's not an exhaust obstruction
- The engine grill is free of stuff and I pulled the A/C anyway, free flow
To do still: look for the baffles/air diverters etc...(not exactly easy) get distr checked... duct air to the fender cooler from my bumper opening...
Duckworth 10-31-2006 04:11 PM
- Verified the flow to the front cooler...
- Verified the front cooler is not obstructed..
Hopefully, you will soon be able to confirm airflow thru the REAR (main) cooler. Unless you've already confirmed - have a friend hold a 2500 rpm speed and sneak your hand up to feel lots of air coming thru.
______________
'82 Targa - sold
'80 928
JP911 10-31-2006 04:12 PM
35 total advance seems really high for a stock SC. That's the timing used with a carbed engine. You should stick with the factory recos on timing unless you're running high octane fuel.
audi2.7t 10-31-2006 04:25 PM
IMO you are ducking the most obvious culprit...air baffles and air flow. All this "Opened the front bumper " and "added extra cooler" are not addressing the problem. You need to verify air flow over the cooling fins. The timing (I'm pretty sure)is not the problem, all your extra bandaids would have compensated for this. One other thing that maybe you should do, once the car reaches high temp on the guage take an actual temp reading of the oil with a laser thermometer to make sure you're not chasing a ghost reading.
patkeefe 10-31-2006 04:26 PM
Greg:
I applaud anyone who can make this kind of effort in troubleshooting. Here is some light reading; I think you are on the right path regarding ignition timing. Have you checked your fuel delivery?
http://cafefoundation.org/pdf/ignition1.pdf
