Suitable engine lift on sale at can tire?
This is on sale at for $59 (1/2 price.
![]() My question is: as it does not rise or lower vertically (as in not dead straight) going to be an issue? It looks like it has wheels front & back, so I 'spose you could move it back as the engine came down. Last edited by dagriff; 04-10-2008 at 03:58 PM.. |
sudo apt-get purge 930
You really need 4 wheels to do the job right. If you can add front wheel cheap then it would be a good deal. It's going to suck in a major way to move that without four wheels once you get the engine weight on it.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I should go look, but it appers to have wheels or rollers at the front.
AutoBahned
the Sears cheapo is cheaper than that by $10 - there is a pic or URL in last weeks 'lift' thread
That's exactly the one I used. It has 4 wheels on it. Worked well, used 2 4x4 blocks on it.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
there is another style on trans jack that lays flat completely(the bottle and the handle). The type that is posted, the handle and jack is fixed.
Whenever I use mine to install my VW or Porsche engines, this gives me issues. The bumper is in the way because of the handle. my .02 |
Bolt a 2 ft x 3 ft 1/2 inch piece of plywood to the lift arms. This will fully support the engine and trans axle as it is removed and reinstalled. No danger of falling.
I have found it necessary to temporarily lift the body with a separate jack to clear the alternator and intake assembly, after the engine/trans has been pulled rearward out of the tunnel. I use a 1 ft x 2 ft x 1/2 inch piece of plywood against the underside to lift the car the additional few inches to clear the motor. Of course the front wheels are chalked safely in position. Simple and safe.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
dagriff, what is the max lifting height on that jack? Also, do you know the spacing of the lifting arms?
Thanks. |
There is a scissor lift at princess auto. I think it goes on sale regularly I was limiting myself to one tool purchase a month and I picked up an engine stand so I passed on the lift. Anyway I hope it will go on again. I think it would also work well.
