scott matre
Guest
Posts: n/a
Response to Mike Miller
Dear Mike,
IMHO, the fans have made a noticable difference in both the engine temps and AC efficiency. I have posted results taken with an infrared heat gun in the past, you could search as I can't remember the date.
In summary,
I have the fans rigged to run with the AC and for 2 min after you turn the car off.
I know the following:
-I have been stuck for 45 minutes in 90+ sunny day with the AC on and the oil temp never got much over 1/2 way between the 2nd and 3rd lines (white)
-The AC blows as cold at idle as at speed now.
- My vent exit temp with a full R12 charge is 31 deg with 80 ambient
- You can feel an ENORMOUS amount of heat coming from under the car with them on.
- They have not effected battery life for starting the car
- I have even seen the car cool down in rushhour traffic with them on. For instance, if I am driving on a hot day, the oil temp gets about 2/3 of the way between the 2nd and 3rd lines. If I switch the fans on, within 4-5 minutes, the temp cools to just over the 2nd line on the guage.
The old post will explain exactly what I used and did. If you need additional info, write me direct at Scott_matre@yahoo.com
I gotta say that for the $150 I spent on it, I feel it was well worth it. I have shown it to other 911 owners and they also agreed.
Good luck!!!!
Old 07-23-2000, 08:16 PM
patalive
Guest
Posts: n/a
I must be doing something wrong because every time I try doing a search, I am getting a Code 400 error - Incorrect syntax.
Anyone else find Scott's prior posting on the A/C fan installation?
Chuck
Old 07-24-2000, 04:10 AM
scott matre
Guest
Posts: n/a
I have found them and re-posted them today. Post 1 is listed as "cooler Carrera" post 2 is Fan update. Hope this helps.
Old 07-24-2000, 06:38 AM
