-   -   Need front oil cooler lines...how long and what size? (http://forums.pelicanparts.com/porsche-911-technical-forum/310738-need-front-oil-cooler-lines-how-long-what-size.html)
rennch 10-20-2006 02:30 PM
I am going to order up some braided stainless lines for my front mounted oil cooler (An RX 7 unit modified with AN fittings.)
Where exactly do I need to start measuring from to determine length, and what's the proper size I need to fit to my oil system?
Thanks!
SoCal70RSR 10-20-2006 02:45 PM
Mike,
What size hose are you looking for? I have 30 feet of -12 braided hose I may sell if I end up going with -16. I paid $300 a couple months ago for the best quality -12 I could find. 30 feet may be an overkill (by about 6- 10 feet) but I decided to error on the side of too much. Either way, let me know if interested. I could sell it for $250 including shipping.
Brad01mc 10-20-2006 02:58 PM
Hi!
I have some hard lines that I am looking to sell. PM me if you are interested. One has a 10" crush, the other is perfect.
Anyway, let me know.
Brad
rennch 10-20-2006 03:59 PM
Hey Brad,
Can the crush be fixed somehow, or am I better off just getting a line of braided stainless?
Brad01mc 10-20-2006 05:21 PM
Hi!
I don't see why you couldn't find a new section of tubing and just braze it in. BTW, it's about 50% flattened. It was crushed by the PO. There are some threads about heating the line up and using compressed air to "pop" out the dents, but I think it would be just as easy/good/better if you "patched" the area with new metal (less fatigue from heat and bending).
As far as the stainless, the reaction that I got, was to find some used replacement lines and not bother with the braided lines.
I never got an explaination, but I was able to find a replacement for my line...even though, I had to buy both lines, the termostat and the flexlines. I ended up biting the bullet it a bit, and now I have these parts lying around, without a home, but I'm happy to help out a fellow pelican, if I can.
Brad
rennch 10-20-2006 05:26 PM
Hey Brad,
Thanks for the heads up. Since I'm venturing into unknown territory with the smushed lines, it would have to be a great deal for me to pull the trigger on it...I wouldn't want to get burned (no pun intended) by it.
I was going to do my rockers this weekend, and I thought about maybe running the stainless lines through the rockers. But I would consider the hard lines if I could figure out a way to fix 'em. (Maybe hire a plumber or something....)
klaucke 10-20-2006 07:15 PM
The hard lines are easily fixable by pressurizing the lines w/ compressed air, and using a torch to heat the dented areas until they pop out. Search the archives there are some threads on it and some have posted really good results. I haven't heard of anyone ruining or hurting a line w/ this technique.
rennch 10-24-2006 11:39 PM
I can get AN -12 for about 150 for 20 feet. Will that be enough to get me started, and is that the right size for typical oil lines?
