pjv911's Avatar
Send a message via AIM to pjv911
Difference in rear control arms early steel S
I know the 67s and the 68s/l have different rear control arms than the normal cars. Can anyone point out the difference for me ? Is it the caliper bolt spacing ?
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 11-02-2006, 04:34 PM
ttweed's Avatar
Kurt-
AFAIK, the only difference was that the S model always had the ball-end pin for the ARBs welded on the trailing arm, and the others didn't, unless they were optioned with a rear sway bar.
Caliper bolt spacing is the same. The only difference on the rear brakes for the S was the vented rotor vs. solid, and that was solved by a spacer in the caliper body to widen the throat, plus a different E-brake setup.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 11-03-2006, 06:07 AM
