83sc fuel distributor question???
Simple question, how do u know when u need a new fuel distributor??? Ive tried everyway of trying to adjusting it??
Old 10-22-2006, 01:16 AM
when all the pressures are good on the WUR Side and you have trouble shoot it accordingly with ben watts CIS book. Then you will find it was shot. I had the same problem with mine and opted to go EFI as the parts in the long run were cheaper and a little better technology
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-22-2006, 05:37 AM
Somatic Negative Optimist
Gunter's Avatar
Re: 83sc fuel distributor question???
Unless you have the right equipment, and know what you are doing, how can you properly adjust a FD and get the correct metering?
Send it in for a rebuild.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-22-2006, 08:45 AM
930turbo's Avatar
The fuel distributor does very little in determining your mixture. I believe they are blamed for other failures. The WUR (control regulator) is a more significant suspect. The distributor will effect cylinder mixture balance. The control pressure delivery volume is also controled bt the distributor. If it falls outside the design range, the WUR can not function correctly. If your problem is overall mixture, I'd investigate elsewhere prior to investing in the distributor. If it's only a cylinder or two, you could be on the right track.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 10-22-2006, 01:07 PM
