-   -   Strange protrusion from under clutch (http://forums.pelicanparts.com/porsche-911-technical-forum/311165-strange-protrusion-under-clutch.html)
SP2 10-23-2006 06:59 AM
I removed my tranny yesterday. I noticed this well lubricated bar with a gear on the end sticking out. It looks like it is the bar that the clutch fork swivels on. But why did it fall down? It definitely wasn't sticking out when I disconnected the clutch cable, spring etc before the drop.
Is this a problem?
I am a newbie mechanic.
Thanks!
http://forums.pelicanparts.com/uploa...1161615508.jpg http://forums.pelicanparts.com/uploa...1161615539.jpg http://forums.pelicanparts.com/uploa...1161615562.jpg
john walker's workshop 10-23-2006 08:22 AM
looks normal to me. the long arm probably slipped off and exposed it for all to see.
Gunter 10-23-2006 08:46 AM
SP2:
Add your year to your signature; it helps.
If it's an SC, there is a good schematic in the Bentley 301-5 showing the various parts/bushings, etc.
Check the bushings/seals, replace if needed and use lube on re-assembly.
SP2 10-23-2006 09:49 AM
Gunter,
My signature does have my year on it. But I list 2 cars, and it is the 1981 SC that I am working on. I am looking at Bentley 301-5 now. Thanks. I didn't realize that it protrudes that much. JW also explained it to me. Thanks!
