Philsy
Guest
Posts: n/a
911 SC gearbox drain plugs
Just went to change the gearbox oil in my 83 SC and found I needed large internal hexagonal drives. Doh!
Can anyone let me know what size internal drives I need to buy for this job?
Many thanks
Old 07-29-2000, 08:43 AM
Early_S_Man
Guest
Posts: n/a
It is a 17 mm hex drive, the same that VW has been using for decades ...
Warren Hall
1973 911S Targa
Old 07-29-2000, 10:34 AM
Philsy
Guest
Posts: n/a
Thanks Warren, I'll buy one in the morning, and then get dirty.... ;-)
Old 07-29-2000, 10:58 AM
Jim Smolka
Guest
Posts: n/a
Instead of buying the hex 17mm allen wrench (late night, all the stores are closed etc...), I took a 10mm bolt and 3 10mm nuts with 17mm hex. I tightened the 3 nuts onto the 10mm bolt. Then I used a 17mm socket and a 1/2" drive. Works great.
Smoke Daddy
Old 07-30-2000, 07:50 PM
