Send a message via AIM to ViR2 Send a message via Skype™ to ViR2
What oil to use in 901?
Hi,
I want to change oil in my tranny, what oil should I use? And how much of it?
Tranny is 912 901
Regards,
Kristijonas Valius
'65 Porsche 912 #994
Old 05-07-2009, 01:10 AM
gear oil
Swepco 201 which is 80/90 wt. is the choice fluid
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-07-2009, 05:58 AM
0396's Avatar
I was advised 201 or 212 with moly
Old 05-07-2009, 06:20 AM
gear oil
I have not used the 212 w/moly, we have tested other slippery fluids in the early style 901/915 syncro systems and it seems to work too well by not letting the syncro design do its job... we always go back to 201 swepco
Mike Bruns
Old 05-07-2009, 07:07 AM
Thank you
And how much is supposed to go in there?
Regards,
Kristijonas Valius
Old 05-07-2009, 07:56 AM
capacity
1 gallon will be more than enough, 3qts. plus
Mike
Old 05-07-2009, 08:11 AM
great to hear, thank you again
Regards,
Kristijonas Valius
Old 05-07-2009, 08:17 AM
