Porsche Crest Flat Battery?
hello.
The Battery on my '77 911 is now flat, and was wondering if there is a specific battery i need to replace the flat one with. Also what brands of batteries should i be looking out for? Any help would be appricated.
1977 911 w/'83 3.0L
Old 11-09-2006, 07:20 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
A lot of guys here like the Optima Red.
I have an Optima Yellow. Great battery and I'm installing a battery mount for it this weekend after I preserve the entire deep area of my trunk. A PO's battery leaked acid everywhere and it will finally be cleaned out properly this weekend.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 11-09-2006, 08:49 PM
Odyssey PC680 MJT
After seeing one of these on another post, I just ordered one. Smaller and lighter than a regular battery. Cheaper than a Optima. Look on E-bay.
Old 11-10-2006, 07:55 AM
dickster's Avatar
Re: Odyssey PC680 MJT
Hi
I've been able to source one in the UK, however does it use the OE mounts, or what did you use?
Mmmm, the one available seems to be a motor bike battery Odyssey PC680 MJ?
Thanks.
Rich
'86 coupe
"there you are"
Old 11-19-2006, 10:27 AM
Odyssey Mount
Funny you should ask. I picked up an aluminum angle iron at Home Depot yesterday. I'm going to fabricate something, hopefully.
Tom
Old 11-19-2006, 10:38 AM
