mackgoo
Guest
Posts: n/a
Hand throttle
Could some one explain in detail how the hand throttle actualy accomplishes it's function. Warren in the spare parts catalogue does it show how it interfaces with the throttle?
Old 08-01-2000, 03:26 AM
Early_S_Man
Guest
Posts: n/a
Bruce,
There is a cylindrical, slotted bushing, called a nipple, that is clamped to the throttle cable by a set screw. A slotted lever or link attached to the throttle lever, pulls on the link, and thus the throttle cable, indirectly, through the nipple clamped to the cable.
Warren Hall
1973 911S Targa
Old 08-01-2000, 08:30 AM
mackgoo
Guest
Posts: n/a
Two questions: 1. When operating the hand throttle does the pedal move? 2. Does the hand throttle move with pedal operation?
Old 08-01-2000, 09:33 AM
GeorgeK
Guest
Posts: n/a
Bruce,
Question 1: YES
Question 2: NO
Regards, George
Old 08-01-2000, 11:39 AM
mackgoo
Guest
Posts: n/a
how?
Old 08-01-2000, 11:45 AM
GeorgeK
Guest
Posts: n/a
Bruce,
The "fork" that pushes on the bushing is behind it in the movement of the rod when you give gas, so the fork can push the throttle rod, but the bushing can't pull the hand gas' fork.
If you lift the handbrake assembly and get a peek, it all becomes much clearer...
George
Old 08-01-2000, 12:14 PM
Early_S_Man
Guest
Posts: n/a
No, the hand throttle does not move with the foot pedal, since the 'link' can only pull on the nipple clamped on the cable, but is not attached, hence can't be pulled by the cable. Yes, the foot pedal does 'fall' a bit when the hand throttle is raised.
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 08-01-2000).]
Old 08-01-2000, 12:55 PM
mackgoo
Guest
Posts: n/a
Thanks, I sort of understand now. You set a false stop with the hand throttle correct?
Old 08-01-2000, 01:29 PM
