Fuel Sender
My fuel sender in the top of the tank leaks. The prior owner had the tank sealed on the inside with some kind of polymer or resin type coating, and too much must have accumulated at the bottom of the tank beneath where the sender sits. Therefore the sender cannot properly compress the stock cork gasket.
Can anyone think of a workaround? The prior owner made a 1/2 inch cork gasket, but it ailed in short order. Any suggestions? Also, any recommendations as to a sealant/glue to use along with a gasket? Thanks.
1972 911T/S MFI Survivor
Old 10-29-2006, 07:39 AM
Anyone?
Old 10-29-2006, 08:54 AM
Bump.
Old 10-30-2006, 08:21 AM
vash's Avatar
you mean you cannot clean the material off? if not that sucks. the factory gasket works great.
poof! gone
Old 10-30-2006, 08:24 AM
The additional material is coating on the bottom of the tank - it's not reachable.
Old 10-30-2006, 08:35 AM
vash's Avatar
o man, that sucks. no way you get can get an alum spacer made. those studs are short! i wonder if there is a way to shorten the sender? i may have a bad unit in my garage to butcher for scientific purposes if you are interested.
poof! gone
Old 10-30-2006, 09:25 AM
Very interested!
Old 10-30-2006, 09:26 AM
vash's Avatar
k, i will search for it tonight.
poof! gone
Old 10-30-2006, 09:31 AM
