kide's Avatar
Leak around Front Oil Cooler - anything to watch out for?
Hello all,
I've been getting a drop or two on the garage floor after drives near the front oil cooler. The car is an 85 3.2 Carrera. I am thinking of replacing the flexible rubber hoses that connect the front oil cooler and supply / return lines.
The hoses are shown in the pic (pic from our host's parts page)
They seem simple enough to replace, but I wanted to ask the experienced before doing it - are there things I should look out for or anticipate?
I plan to remove the right front wheel, unscrew the hoses and replace. I do not plan to drain oil, as I'd guess that with the engine cold and the position of the hose, there won't be much oil there anyways. I will have some newpaper underneath, though.
Thanks for your advice.
Old 10-25-2006, 01:08 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest
Be careful. I had mine done a few years ago by a Porsche mechanic.. The fitting of the oil line was corroded to the oilcooler threads. It cost me a new cooler ($$$$$).
Old 10-25-2006, 02:13 AM
kide's Avatar
Thanks Kees. I hope I don't have to change the cooler... I guess I'll have to remove the hoses to find out.
Old 10-26-2006, 01:00 AM
