no spark from plugs, but coil gets spark.
I now have my carb issue figured out and was attempting to start the car today. but its not getting spark though the plugs, it does however make it to the coil. the cap and rotor seem to be in good shape. any wiring that would cause this?
71' 911T Targa, current toy. 86.5 928s traded for new 911 71 911 Targa w/ gas burners, PMO's, *sold* Lamborghini diablo replica w/ 350 V8 85.5' 944 n/a euro ( gave to dad ) 87 fiero cp. candy blue, chrome 16's 90' DSM 24psi. 18G fmic, 82' benz 300sd turbo, intercooled. 73' Karmann Ghia cab. sold 04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs, check out www.vintagevwcars.com wanted: 914, 944, 928 project |
Not that I can think of. First, use an Ohm meter on your rotor.
Have you pulled the plug out, ground it and see if it fires outside the combustion chamber? SAFETY percautions !!
Are the plugs dry? When playing with carbs and there's no spark, check for fouled or wet plugs.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Registered abUser
I'm guessing the points aren't opening or are burnt. I'm also guessing you have points. Not sure what year we're working on.
Registered abUser
sooooooo........ are the points arcing? I bet not.
Maybe I didn't understand his post, but if the coil is shooting, then the points are working, no? But, somehow, that spark is not getting to the plugs. Not to be smug, but where would you look?
I could be wrong, and I'm guilty of leaving the rotor on the bench, too, and then wondering why no spark. Doh. |
BTW the coil is making spark as soon as you turn the key into the on position. not when you turn it over
Registered abUser
Back in the olden days, I used buy points by the 12 pack and I think they came with condensors.
Assuming the spark is getting to the cap, if the condensor is dead, you will get no useful spark at the plug either.
There is a way to check the condensor, but I can't remember it. But there are not too many options from the cap to the plug, and replacing the condensor is not expensive. With the ignition on and the points on closed, you should get a spark by opening them with an insulated screwdriver, - each and every time. If only once or twice, then condensor not charging up enough. Make sure the pin in the top of the cap is not jammed up, short of contacting the rotor - assuming the rotor is in. If the cap has a crack in it, it will earth out rather than fire down the high resistance leads. It needs to be well insulated, not earthed. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
New ball game. How he tells us the spark for the coil is only a one time spark when he puts power to it, but not when cranking. I'm out.
such an issue with a 911?
When the condensor is shot, it will not repeatedly recharge quick enough to keep up with the points. They are bouncing around at 000's of rpm (or at least 00's on start up), and the condensor needs to charge at the same rate for a spark. As the condensor ages, it leaks charge across the barrier that is supposed to allow it to build up the potential difference in voltage. So it simply can't build up and hold enough voltage quick enough to deliver a spark. But in a static test may be able to do so once or twice, or at very slow openings. I would definitely throw the old one out and see if it makes a difference.
Another option is the battery using all the power to crank the motor? If the battery is in good nick, look at the condensor. Alan
good battery from my benz ill order a condenser, pionts, and a new rotor.
the coil does NOT make a spark as soon as the key is turned on. cars without the CD unit did, but not porsche. basic ign systems, switched 12v is applied to one side of the coil and the points are on the other terminal.
on the 911, the CD unit is connected to the terminal where the 12v was applied and the other side of the coil is grounded. the switched 12v is now applied to the CD unit. the points are now connected to the CD unit. there is no voltage on the points so they dont burn like they use to. the points simlply open and remove gound from the CD telling it to send about 450v ( vs 12v ) to the coil. the coil is a step up transformer of about 100:1 making a 45,000v spark vs 1200v. you really dont need to set the gap on the points, as long as they open and close completly the car will run. porsche saw the importance of a higher voltage back in the 60's. this higher voltage is why we can set our plugs to .050" .060" if the coil is sparking, check the rotor and cap. milt, i too have left the rotor on the bench....more than once.
this guy has PMOs.
Maybe he has MSD that toasted a rev limiting rotor ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
ronin,
has an MSD toasted a rev limiter before? i cant see that happening. my permatune is bad so i was planning on trying an MSD...because of the cost ($170)?
I use non-rev limiting VW rotor
Pelican Parts pn Bos 04038
