Repairable Heater Blower? (pics)
Hi folks,
Just took out my heater-blower assembly, and found that the cage wasn't attached to the motor. I can't figure out how it was supposed to be attached in the first place, am I missing a component - is this fixable?
Here's what it attachment on the cage looks like:
And here's the motor:
Bonus: anyone know when the motor is activated? Does the car have to be on, and the heat levers all the way up?
Thanks!
Babak
Old 06-17-2007, 04:25 PM
aj88cab's Avatar
That twisted piece of metal in the middle of the mounting plate is what is left of the bushing that sheared thru the shaft of the fan. The stub that is at the middle of the fan is what is left of the shaft. You need a new motor/fan unit, available from our host. Or do a search for options for mounting a Grainger motor to the fan housing.
Bonus ?....Yes, the car needs to be on and the levers up (actually the fan should start with just a little movement of the levers).
Good Luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 06-17-2007, 05:07 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Took mine off a few days ago and have no use for it...thats the fan that sits on top of the engine correct? It worked great before I took it off. give me a price and its yours-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 06-17-2007, 05:14 PM
On some of the cars, depending on the year, the fan is always on with the ignition.
Dave
'75 911s Coupe
Old 06-18-2007, 12:01 PM
Thanks for the info folks - guess it's probably not worth super-gluing the axel together. =)
Old 06-18-2007, 08:40 PM
Scott R's Avatar
I have one as well if you need it, if you don't take Chris up on his generous offer. Backdated and I had a perfect working fan at the time.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-18-2007, 08:46 PM
Evil Genius
Rusty Heap's Avatar
For those of you with perfect working fans that have been removed,
(please test them with 12 volts and make sure no howl or bad bearings, like the used one I bought, put on my engine, and now it howls with bad bearings. groan)
I'll send you $50 for your fan motor/blower housing. Shipping to 98294 seattle.
Please test your motors, or make me a counter offer and pm me with it.
Life is a big ocean to swim in.
Wag more, bark less.
Old 06-18-2007, 09:17 PM
madmmac's Avatar
I also need one for a 1984 3.2.
The previous used one I got was DOA when I received it. The upstanding Pelican refunded my money, but I still need another blower.
You can PM me with what you have......Thanks
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 06-19-2007, 06:06 AM
There is supposed to be a thread on replacing the motor with a high-efficiency Granger (sp?) motor.
When mine dies, i'll pursue this route.
Old 06-19-2007, 06:48 PM
fty fty is offline
fty's Avatar
Mine is off of a 87 3.2...looks fairly new and I just bench tested it...no howling, turns over immediately and seems to run perfect. Who wants it, shoot me a PM. SOLD...SOLD
Old 06-19-2007, 08:01 PM
fty fty is offline
fty's Avatar
Thx for the purchase Dave, shipping it this morning-chris
Old 06-21-2007, 09:00 AM
