Innov8's Avatar
tires for 7 & 8" 16" Fuchs (951)
What size tires fit 7 and 8 inch x16" rims off a 951? They will go on a 82 911 sc that has been lowered and mildly tracked aligned... with standard brakes? What do you recommend? Thanks.
04 996 AE (daily driver)
08 A3 Quattro
05 E500 Wagon
PO: 11 Raptor SCREW, 11 GTI 6sp mt, 01 Audi S4 Avanti, 95 Volvo 855 T5R, 82 911SC
Old 10-06-2006, 06:14 PM
lally911's Avatar
225x50 for the 7s and 245x45 for the rear.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 10-06-2006, 06:21 PM
Innov8's Avatar
Thanks! Are there any issues with offsets or brake clearences? Your help is much appreciated!
08 A3 Quattro
05 E500 Wagon
Old 10-06-2006, 06:45 PM
klaucke's Avatar
The 951 8" wheels have more offset than 911 8's. Although there will probably not be any rubbing they won't fill out the fender as well. The 7's are the same as the 911 7's except they have the look of a 6" and more caliper clearance (same offset though).
Old 10-06-2006, 07:01 PM
don911's Avatar
I have 225/50 and 245/45 Hankook R2Ss on my 951 7s and 8s. I'm using a 5mm spacer on the 8s since they don't fill up the fender well. I have a lot of camber so they may look better on your car.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 10-06-2006, 07:40 PM
Like everyone said, 225/245s. The 951 8s have a 23mm offset, which puts it 13mm further inside the fender lip than the 911 8s (10mm offset). If there was any clearance issues, I think it'd be with the oil lines on the right rear. If it were me, I'd probably run them with longer wheel studs and a 1/2" spacer to fill out the wheel well as much as clear the lines.
I have 951 8s with 225s (front tires) and have put them on the rear with no clearance issues. Never tried 245s on them, though.
Chris M
1985 911 Carrera w/ 3.6
Old 10-06-2006, 10:18 PM
rhymes with targa
Bearded Viking's Avatar
don911
Can you post some pix of your 245\45\16 hankooks please.
thx
Old 10-27-2006, 01:31 AM
