Remove The Speedo & Window Stops Working...uh??
After removing the Speedo and Clock from the dash my passenger window has stopped going up. The motor does work. I have confirmed that the red/white wire that comes from the drivers door does not have 12volts on it. (see Pic) So that is the problem, but how did it happen? By removing the instruments from the dash could I have bumped a relay or some how damaged the wire coming across the car? Any tips on where to start to look would be great.
Thanks R http://forums.pelicanparts.com/uploa...1161959016.jpg |
I had my speedo out last winter. The windows still worked a-ok. You probably did check the fuses, right?
I do seem to recall something about the clock circuit wired with the trunk light or something; can't remember exactly. jt -84 targa |
| All times are GMT -8. The time now is 11:18 PM. |
