FinallyGotOne's Avatar
Post more about the '79 911sc smog pump removal situation....
Okay, So here is where i'm at: I removed the smog pump/air pump and I plugged up the hole in the diverter valve. I poked around under neath the back of the car and noticed that this odd little part (Diverter valve) seems to be attached to something under the car. some long metal tube that winds it's way toward the middle of the motor/ and the other hole on the diverter valve is just a open space that goes under the car. So I tried to undo the bracket that held on the air pump but could not because the diverter valve is in the way. So I'm a bit put off because I'm worried that if I were to just plug off the diverter valve, it may not pass emissions. and that this may make the car run weird since I've now read that this could be problematic. i am talking about a book called: PORSCHE 911 BUYERS GUIDE BY RANDY LEFFINGWELL. (page 108) It says originally owners believed that without the air pump the car performed better but over time the performance deteriorated without the system in working order. So maybe it's best to buy a remanned air pump and hook it all back up. But before I do I have to replace that left heater hose because I really cannot reach it with the air pump on!
I just am not 100% sure how this system works. Whats with the steel tubing iattached to the diverter valve? and if i plug that off how will it affect the vacuum?
Old 10-27-2006, 10:04 PM
When I bought my 78 the smog pump didn't have the belt on the pulley. The pump was removed and I've never had any problems that were directly related to the removed pump.
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 10-28-2006, 06:58 AM
Tho hose from your smog pump goes into the diverter valve. so is that just plugged up, that's all? I tried that and when i started it it ran odd(like real rich) it smelled badly of fuel?
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 10-28-2006, 07:52 AM
OPkay. I seem to be good on my deck lid strut issue/
I went to Home depot and bout 10mm 2 inch bolts. Bought rubber washer and lock washers and a few nuts. I bought two struts from our host. On the driver side I put the bolts through with the first strut where the strut goes and on the outside of that strut I put a few spacers on the bolt and the other streut. It works like a charm!
Old 10-28-2006, 03:08 PM
