-   -   Why would replacing DME result in slight reduction of power? (http://forums.pelicanparts.com/porsche-911-technical-forum/311908-why-would-replacing-dme-result-slight-reduction-power.html)
movin 10-27-2006 02:06 PM
'87 DME died a while back and the replacement was the newer version with 28 pins. The old DME's chip had fewer pins. Thing is I noticed a slight reduction in power. Puzzling. BTW, both had S.Wong chips, same parameters. The old DME just made the car more powerful in the top end.
DW SD 10-27-2006 02:48 PM
odd issue. I'd venture that they are not the same parameters. Did you double check with Steve?
Any chance your car gained weight? How much difference? Any other changes?
Doug
Por_sha911 10-27-2006 04:18 PM
Dumb Question: Did Steve custom program both chips for you? Is it possible that one chip was programed differently than the other?
ewave 10-28-2006 12:04 PM
The extra weight of the 28 pin part over the 24 pin part is slowing the car down.
johnnyo 10-28-2006 01:32 PM
Any possibility one DME was from a ROW and the one you have now is US ? Just a stab in the dark
livi 10-28-2006 02:10 PM
I will be very interested to hear Steve comment. I have zero knowledge of course (so why don´t I shut up?), but could it be that the newer 28 pin is designed to go with a bit different input parameters so although "programmed" identically with the old chip, it does not produce identical output ?
OK, I should have shut up.. :D
ewave 10-28-2006 03:21 PM
Originally posted by livi
I will be very interested to hear Steve comment. I have zero knowledge of course (so why don�t I shut up?), but could it be that the newer 28 pin is designed to go with a bit different input parameters so although "programmed" identically with the old chip, it does not produce identical output ?
It's just an EPROM... It contains the code that the cpu (an Intel 8051) runs. So if the eproms have the same programming, the output would be identical. I think my pin weight theory is correct. Try driving back to back experiments with your eyes closed to see if you can still tell the difference between the two DME's.
