Question Replacing Interior Rear deck under Pad
I would like to replace the foam and fiber noise insulation pad on my 70 911. This is the pad that is glued to the metal inside the car, under the rear deck panel.
Anyone know where I might find this part or the material? It seems to be more then just a dense foam.
Thanks,
Stephen
Old 10-26-2006, 11:27 AM
poorsha's Avatar
I have all of hat material I removed from a 72 coupe years ago when I built a RS clone.
It is a heavy dense material.
Where are you located?
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 10-26-2006, 12:05 PM
David's Avatar
Pelican sells the original type and the foil type. Both types are much lighter than the original material.
Old 10-26-2006, 02:48 PM
Double Trouble
targa911S's Avatar
why?
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 10-26-2006, 03:54 PM
Thanks for the reply's.
As to why I want to replace it; It fell apart as I removed it to so some rust repair in the rear firewall/sill. Rear Window seal had been leaking.
The Material Pelican sells is for the engine compartment, not the interior. Right?
And lastly to Poorsha, I am in So. Cal.
Stephen
Old 10-27-2006, 02:18 PM
Old Member
Stephen
If you want a used one, I have the pad removed from my '78SC. It's in great shape, a combination of a rubber pad and fiber material. No damage to pad during removal.
I think it could be rolled for shipping.
Clifton Brown
https://www.mancalamarketing.com
Old 10-27-2006, 03:29 PM
