JackOlsen
Guest
Posts: n/a
Early 911 oil-cooler scoop?
Is it possible to use a 1973 911's horn grill to vent air to a wheel-well mounted oil cooler? I realize it would involve cutting some sheet metal -- but can it be done?
Should it be done?
Jack Olsen
1973 911 T sunroof coupe
http://members.rennlist.com/jackolsen/Jalopy.html
Old 08-05-2000, 02:19 AM
RLJ
Guest
Posts: n/a
I have seen early 911 race cars that use the horn grills for brake cooling, they punch holes thru the battery boxes and on to the rotors. Might as well use the hole for someting good IMHO all they do is cause up lift anyway and the air horns don't use them for sound exit.
Randy Jones
1971 911
[This message has been edited by RLJ (edited 08-05-2000).]
Old 08-05-2000, 01:35 PM
campbellcj
Guest
Posts: n/a
That raises a curious question -- why the heck do they call them "horn grilles" when on the 911 the horns are about 1ft. below the grilles??? Very odd.
Old 08-05-2000, 02:07 PM
RLJ
Guest
Posts: n/a
On the real early 911 and even the 901 were the electric horns not in back of or near these little openings. I have seen racers plug the holes with thin plastic to stop the lift.
Old 08-06-2000, 12:29 AM
