3.6 Case through-bolt o-ring leak
Need advice on solving a leak at case through-bolt o-ring.
History: Purchased fully rebuilt 964 3.6 engine. Installed in car. Runs great! DRIP. DRIP, DRIP, driver's side o-rings leak badly. Builder must have cut the o-rings during assembly.
My plan is to remove engine/ heads/ air cooling shields to access both sides of the case thru-bolts, replace the bolt o-rings one at a time, hopefully without disturbing the cylinders/ rings.
Any words of advice so I can avoid the same mistake by this "reputable engine builder" ? Where can I get o-rings? Pelican doesn't list the o-rings separate. Hopefully these are not the cheap "blue" Victor Reinz o-rings that come in the 2.0 to 3.2 911 kits?
Coaching encouraged! Thanks
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 10-28-2006, 06:25 AM
Somatic Negative Optimist
Gunter's Avatar
It seems that the O-rings can get distorted when tightening the trough-bolts. The beeech is that you cannot get at them.
What is the general practise? Just use oil on the O-rings when tightening? RTV Silicon sealant recommended by Wayne in his book?
I remember people mentioning green Viton O-rings instead of blue?
Is the leak coming from the nut-side?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-28-2006, 08:01 AM
the P+Cs need to come off to deal with the o-rings. green viton only! never use the blue ones for anything. call around to the local shops to find them.
206 637 4071
Old 10-28-2006, 09:06 AM
